Barely Running After Rebuild
  • SPARTAN
  • SPARTAN's Avatar Topic Author
22 Jul 2008 12:41
#227670
Alright, so I took the engine apart and installed brand new gaskets. I put everything back together, torqued everything, made sure timing was at TDC. Now
It runs sorta...
I get a backfire in the exhaust and a little in the carbs.
I made sure the coils and are in right, and the wiring is in right.
Now I'm confused...
I can get it to run but it dies almost instantly after I let off the gas.
Is my timing out again or what?
please help!
  • mtkawboy
  • mtkawboy's Avatar
Re: Barely Running After Rebuild
22 Jul 2008 12:45
#227673
If it ran OK before the rebuild I think Id double check the cam timing. Did you static test the timing hitting the marks on both pairs of cyls ? Got the valves set right ?
  • SPARTAN
22 Jul 2008 13:28
#227683
I did Neither.
  • jordan
  • jordan's Avatar
22 Jul 2008 16:14
#227722
when you refer to having the valves set right, are you referring to setting height with shims?
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold :(
1972 Kawasaki s2 350-parted on ebay :(
1973 Kawasaki s2 350-parted on ebay :(
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
  • wiredgeorge
  • wiredgeorge's Avatar
22 Jul 2008 16:51
#227733
Geesh... where to begin:
1. check cam chain timing AGAIN
2. check valve clearances
3. check ignition timing
4. put your darn bike year/model in your signature by editing your profile -
5. almost all Kaws have the GREEEEEEEEEN ignition lead going to the 2&3 coil and the black wire going to the 1&4 coil and make sure the wires coming off the coils are going to the right plugs.
6. make sure you are getting gas
7. check compression to make sure you have compression
8. check spark on all four plugs to make sure you have spark
9. If you have a Dyna S, make sure you have the rotor on the right way
....errrrrrrrrrrrrr time to go eat, there are lots more things but I would start with these...
