- Thank you received: 1
kick starting the bike!
- steveo_4192003
- 77kz650b-1
21 Jul 2008 15:59 #227512
by steveo_4192003
1977 kz650b-1, 4-2exhaust systetm, pod filters ,jetted 112 main, 17.5 pilot
kick starting the bike! was created by steveo_4192003
if i use the kick starter to turn the bike over will it pump oil up to the cams and other passages?
im trying to flush my newly assembled engine to get the small bits that May still be in it !
- slowman
21 Jul 2008 19:34 #227543
by slowman
1979 Kawasaki KZ1000 LTD
The only thing better than the sound of a carburettor opening is the sound of 4 carburettors opening simultaneously!
Replied by slowman on topic kick starting the bike!
It makes sense that it would.
For example, when I start my bike cold the valves do some ticking until oil gets up there.
I always kick it over in neutral with the ignition off about 4 or 5 times before I start it. Solves my valve ticking at cold startup.
- steveo_4192003
- 77kz650b-1
22 Jul 2008 07:03 #227617
by steveo_4192003
Replied by steveo_4192003 on topic kick starting the bike!
thats what i wanted to hear! now it time to get ready to fire her up!
i thought it would, but just didnt want to be wrong!
ill post more pics and stuff in the project area when i can find all my before and after pics to show my 1-1/2 year project kz650b-1
- slowman
22 Jul 2008 08:03 #227628
by slowman
I would imagine that you would want to kick start it more than 4 or 5 times if your ultimate goal is to remove that crap from the engine. Probably 20-25!
I would go so far as to use the electric start with the plug wires off.
- steveo_4192003
- 77kz650b-1
22 Jul 2008 11:03 #227652
by steveo_4192003
i "just" picked up my new battery just for that reason (so i dont have to kick it over a crap load of times!)
i also got 6 qts of cheap oil to flush through it!
