KZ900: Crankshaft Main Bearings, Replace or Not?
  • Old Man Rock
  • Old Man Rock's Avatar Topic Author
20 Jul 2008 07:23
#227211
Hey all,
Question, since I have the cases open and all, should I just go ahead and replace the Crankshaft Main Bearings?
Are these a bitch to get out?
Special tools required i.e. gear puller?
What about pressing in, hows this done?
NOTE: these seem to roll fine, just researching and following up on it while waiting for other parts.
As always, thanks for your input... B)
Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • shighley
  • shighley's Avatar
Re: KZ900: Crankshaft Main Bearings, Replace or Not?
20 Jul 2008 07:33
#227213
Hey OMR; That's a really good question! I'm in the same boat with my Z1. The crank is pressed together and must be disassembles to R & R the bearings. Then of course, it must be pressed back together. I've looked at Falicon crank service and they list indexing, truing and welding service. What I don't know is if they replace all the bearings during this process. I believe they are roller bearings that use the parent material of the crankshaft as the inner bearing surface instead of a sleeve. So, what do they do if one journal is scored? Junk the crank? I don't know this for sure and I haven't had the courage to call Falicon yet as I'm a long way from needing the crankshaft. (Bike is still in one piece, just buying components now) I do know that the issue must be addressed as I'm not going to trust an orginal crank with all my new engine parts.
\'74 Z1-A, Bought new, worn out 3 times, being ridden now
\'83 XVZ12TK, was daily driver until frame broke
\'78 KZ650SR-D1A, Son's bike, I'm the wrench (He's young)!
  • steell
  • steell's Avatar
20 Jul 2008 08:25
#227226
Got a 50 ton press in your garage? I'm pretty sure that will be required to disassemble and reassemble the crank.
And that's the easy part :)
You are also going to need the fixtures and measuring instruments to ensure that the crank is pressed back together correctly, as in absolutely true, not a job for anyone lacking the skills and experience (and tools/equipment).
Check out the KZ forum at dragbike.com for some discussions regarding crank builders. Not cheap :woohoo:
  • Old Man Rock
20 Jul 2008 08:51
#227233
Yup... Been over to Falicon website... $$$$ Ouch!.
Since I'm not going over board with the cylinder and CAM combinations and the bearings seem good, probably leave this one alone.
The crank seems fine where I have no up & down play in the rods. Very slight side movement but from what I've researched this is normal. The up & down movement is the one to worry about. Bearings seem to roll fine.
Thanks guys,
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • FastKaw1
  • FastKaw1's Avatar
20 Jul 2008 10:21
#227259
Unless you are planning on making BIG HP I think you are wasting your money.
If you are starting out with a good crank you should be fine.
Just weld it and go.
  • Old Man Rock
20 Jul 2008 10:35
#227263
FastKaw1... "Just weld it"
Is this something you did yourself or did you have it done by machinist?
If yourself, any tutorials/images on this?
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • FastKaw1
  • FastKaw1's Avatar
20 Jul 2008 11:28
#227278
I welded a couple 25 Yr. ago. Never had a problem with them.
I just bent a rod and welded it. You don't have to weld the hole joint
a 5/8-3/4 in. long weld will do. Up to about 150 HP.
That was a long time ago and thats how it was dun. Thats not how they do it today.
Only because there are much better welders out now, and I don't have one.
The Last one I had dun I sent out. $100 bucks out the door.
If I still had a arc welder I would not hesitate to do it again.
Weld a pin let it cool and weld the next. Takes all day.
I wish I had some pic. of the old days. Make us all LOL today.
I think the three or four most important thing to do for street motor are.
Weld crank
crank + cylinder studs and nuts (APE)
over shift bushing
If you are planning on doing a lot of hole shots a billet 2nd. gear is a good idea.
I hope this helps
ps have you trans magna fluxed before you put it back together... Worth every penny.
  • shighley
  • shighley's Avatar
21 Jul 2008 06:04
#227406
I just love beating dead horses. . . Ok, so I'll rephrase the question. If a person wanted to have the main bearings removed and replaced and the rod big end bearings looked at, where should the crank be sent? Does anyone know if a bad/scored bearing is found, does that junk the crank?
I don't think I need all the fancy stuff (indexing, etc) on my stock Z1 running the 1015/10.25CR kit. Might make 90 HP? I figure the 600-700 bucks saved could buy a few OEM rubber grommets and a decal or two (joke). Please let me hear your thoughts/experiences! Ride safe, Steve
