kx440 ltd missing at high rpm
- Foose
- okay, so im a honda guy......
16 Jul 2008 22:52 #226646
by Foose
kx440 ltd missing at high rpm was created by Foose
okay so ive got an 81 kz 440 ltd that fires right up, valve clearances are great, idles like a champ, but theres the strangest bog that occurs around half to three quarters throttle. ive replaced plugs, carbs are clean, no induction leak, a slight exhaust leak except the studs are so rusted that i dont dare touch them....theyre staying as is. original air filter, no current fuel filter. when you reach that half to three quarters throttle range in any gear it suddenly bogs so har and consistently that it prohibits you from reaching the higher rpms. heres the wierd part. if you back the throttle off to the point just under which it started bogging, the motor will climb through the rpm range without problem, it just does it extremely slowly. when in a high gear and downshifting it does not hesitate at all going to high revs, and as you slow, it backfires like its mad rich. this is why ive decided its not a spark advance problem, but a mixture problem. but as ive been typing this, it occurs to me that i have not checked the spark plug caps themselves yet. come to think of it im not sure the coil itself is up to spec. so heres my question then: what resistance can i expect from the coil, and does anyone have any idea what my issue might be? thanks for the help everyone...
brian
brian
- oldkaws4ever
- Have no regrets...... You only live once.
- Thank you received: 12
16 Jul 2008 23:15 #226658
by oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
Replied by oldkaws4ever on topic kx440 ltd missing at high rpm
well brian, i would start off by getting a new air filter. And i know i heard from some one on here, i think the gringo. The air boxes are really finiky on the 440's, they have to be put back on perfectly or the bike will bog.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- The Gringo
- ¡Usted no necesita otra motocicleta!
- Thank you received: 11
17 Jul 2008 04:35 #226669
by The Gringo
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Replied by The Gringo on topic kx440 ltd missing at high rpm
Yeah Foose the first thing you need to check is that the air cleaner is installed correctly. In order to check it open the seat, grab the back of the filter and try lifting up on it. If the box moves you have it installed wrong and the bike won't run right. There is a slot in the airbox where the bottom of the filter fits into prior to attaching it with the two top screws. This will only take a minute to check.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- Foose
17 Jul 2008 08:03 #226688
by Foose
Replied by Foose on topic kx440 ltd missing at high rpm
i just went out and sure enough i had installed the air filter wrong....after fixing it i have it another ride and the problem persists....perhaps is even worse than before. okay so heres something dumb that i did that i neglected to remember until now....the foam element in the filter was shot so i grabbed another piece of foam from somewhere in the shop, shot it with air filter oil, and replaced the unit. you think im choking it with this foam? will the bike run without the element, but the air box itself installed? i notice the airbox has venturis, probably to stabilize the air, but just to get it running well, do you think i could take the foam out?
- Foose
17 Jul 2008 08:25 #226692
by Foose
i just got back from the best ride this poor old 440 has seen in the last 6 years! i took that foam strip i installed off and like a cheerleader on prom night, the hesitation was gone! gotta hand it to you guys, youre very crafty in your ways! thanks again for all the help....ill post some pictures and the whole story of this bike pretty soon.....its come a long way from the compost pile under a pine tree down the street.
- oldkaws4ever
17 Jul 2008 11:44 #226720
by oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
no problem, im glad we could help you out. And yes pictures are a very good thing here at kzr.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
