- Thank you received: 43
Cam Cover Clearance??
- 79MKII
- Love Them Kaws!
16 Jul 2008 09:36 #226503
by 79MKII
The Kaw List:
Cam Cover Clearance?? was created by 79MKII
How much do I need to remove from a stock valve cover for .425 cams? Just the crosses on the intake side or is there more to do?
How do I check it? I'm guessing by installing the cover and turning it over by hand? Can I hear the contact that way?
This is on the '79MKII project.
Thanks
Thanks
The Kaw List:
- FastKaw1
16 Jul 2008 09:52 #226509
by FastKaw1
Replied by FastKaw1 on topic Cam Cover Clearance??
That the way I do it.
I think you will have to remove just a little more then the crosses
if I remember correctly.
Your doing it right. I don't think there is a wrong way to do it.
- StreetfighterKz
- Thank you received: 117
16 Jul 2008 10:42 #226515
by StreetfighterKz
1978 z1000 Streetfighter
1976 z900 Stripfighter (work in progress)
1983 Gpz750 Resto-Mod
1989 Vmax
Replied by StreetfighterKz on topic Cam Cover Clearance??
I saw on another forum that if you need just a tad more clearence after you removed the "X"s use two gaskets.
Later, Doug
Later, Doug
1989 Vmax
- mark1122
- Keep twisting it
- Thank you received: 109
19 Jul 2008 12:33 #227100
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic Cam Cover Clearance??
Doug is correct. i hope u clearaned the head first though.if not the cams will not turn over.is this a stock motor and head?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- 79MKII
- Love Them Kaws!
19 Jul 2008 16:04 #227132
by 79MKII
The Kaw List:
Replied by 79MKII on topic Cam Cover Clearance??
mark1122 wrote:
Definitely not stock - 1260 kit with ported head, o/s valves, mild porting, etc, etc, etc... Head was clearanced for cams as was old cam cover. I'm switching cam covers to a freshly chromed one and want to make sure I have enough clearance for the .425's.
Is the exhaust side OK as is? My old one has some material ground off from intake and exhaust but is that necessary? I had .435 cams in it at one time with a single gasket and never had any problems. I've heard from some that you only need to remove the crosses and you're OK - just looking for some confirmation on that.
Don't want to beat up my new cams!!:blink:
The Kaw List:
- mark1122
- Keep twisting it
19 Jul 2008 18:45 #227158
by mark1122
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Just remove the crosses on int and xht is a good start but never leave anything to chance. after the x's are ground off, put the lobes up and put a peice of putty on top. tighten down the cover , then temove the cover and measure the thickness of the putty . now u know where u stand . No guessing.
Your motor sounds like mine, but i just went from 1135cc to 1327 cc's.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- 79MKII
- Love Them Kaws!
08 Aug 2008 17:50 #230918
by 79MKII
The Kaw List:
I finally tried out the new cover and had enough clearance. I ground off all of the "crosses" and just cleaned up the exhaust side to be safe. I only used one gasket (as I always had in the past) and it was around 1mm thick. Kicked it over first and listened for noise, then started it, then rode it.
Here's a picture before chrome plating:
The Kaw List:
