valve clearance check with unusal result
13 Jul 2008 20:30 #226002 by avmedco
1983
kz750l3
24K miles
Something is not making sense-hoping you guys can help me out
Was check valve clearance between the cam lobe+ bucket and got:
Exhaust: .102 .102 .025 .102mm
Inlet: .152 .102 .102 .102mm
Spec is .08-.18
I happend to reread the procedure and noticed a note indicating checking the torque before taking measurement.
The torque on the cap bolts seemed very tight. So I loosened and rest to spec @ 104 in/lbs (converts to 8.67 ft lbs) following the pattern in the factory shop manual.
Inlet side measured same as first time. Exhaust side gap is now too tight to take measurements even with a .025 feeler. I can spin buckets with my finger so I know there is a gap must be greater than zero and less than .025. Loosened up and re-torqued several times with same results.
Any ideas why/how the clearance decreased as the cam cap bolts were tight and possibly over tight to begin with?
I'm confident these are the orginal shims. Is there a standard size these bikes were build with......I'm just tring to save time as I can only work on this on weekend and want to figure out what new shims I need.
Thanks
13 Jul 2008 21:19 #226010 by kzwolfsr
Replied by kzwolfsr on topic valve clearance check with unusal result
First of all you don't measure between lobe and bucket, you measure from the rounded base of the lobe if that is what you are meaning. Oil can also change clearance measurements, but dont worry about the changes, just get one main measurement then take out cams and measure shims, don't forget to take notes as you go along. Take notes of measure before removing cams, then on what shims were where then work them out for clearances. And do so much loosening and torquing, that could be more than what was expected for the bikes parts in a lifetime and wear out threaded holes
Original man of the Caribbean
13 Jul 2008 23:25 #226017 by bountyhunter
Replied by bountyhunter on topic valve clearance check with unusal result
Puzzling. I'll throw in what I learned:
Be careful torquing the cap bolts. many have been stripped, and many have complained the 100 inch-pound spec is too much. But, that is what's in the manual and it's what I have always used. I happen to have a very accurate (200 inch-pound full range) torque wrench so I can torque them dead on 100 in-lb. Be careful.
QUESTION: did you loosen one both at a time and retighten each? Did you loosen all the caps and then re torque? That may have let the camshaft shift slightly.
On taking the reading: turn the crankshaft with a 17mm wrench in only the CCW direction (don't reverse) and stop when the valve to be measured points directly away from the bucket. Turn the cams a few revs to make sure everything is seated.
Not sure how all the exhaust valves snugged up except to say maybe the cam was loose?
13 Jul 2008 23:31 #226019 by bountyhunter
NO
Thanks
Measure the gaps accurately and write them down. Note the ones that need changing and by how much.
Take the shims out (can be done with shim removal tool) one at a time and measure with calipers (don't assume marked value is right and many have the marks worn off anyway).
You will be able to calculate the shim you need at each location. In some cases, you can swap shims around and get a couple right and end up only needing one or two new shims.
14 Jul 2008 05:13 - 14 Jul 2008 05:16 #226030 by steell
Replied by steell on topic valve clearance check with unusal result
Umm, nope, no such tool will work on a KZ750L3, it's a 750 four and the shims are under the buckets. You have to remove the cams in order to get the buckets out to remove the shims that are stuck to the inside of the buckets (held there by an oil film).
As to the original post, the bike has 24k on it, the clearances were in spec when you originally checked, and I bet you regret messing with the cams now :)
If it ain't broke, don't mess with it :)
I'm going to have to give this some thought to figure out how it can happen.
Are you working on the bike while it's on the side stand?
Last edit: 14 Jul 2008 05:16 by steell.
14 Jul 2008 07:25 #226045 by avmedco
Replied by avmedco on topic valve clearance check with unusal result
Yes-Measured from rounded base and bucket
14 Jul 2008 07:27 #226046 by avmedco
Loosened all the end cap bolts and re-torqued per pattern and specs in factory manual.
14 Jul 2008 07:32 #226048 by avmedco
Usually I don't mess with things when they meet spec. I was going to have to pull the cam anyway as the one exhaust measurement was way out of spec.
Bike is on it's center stand.
14 Jul 2008 08:59 #226066 by OKC_Kent
Replied by OKC_Kent on topic valve clearance check with unusal result
bountyhunter,
you said turn it CCW, counter-clockwise..did you mean to say turn it CW ? clockwise?
I think that's what you meant... :whistle:
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
14 Jul 2008 12:03 - 14 Jul 2008 12:07 #226111 by bountyhunter
OKC_Kent wrote:
bountyhunter,
On my 750, I believe the correct (normal) rotation of the crankshaft is counterclockwise as viewed from the right end (under the timing cover) where the 17mm nut is that allows turning of the crankshaft.
I noticed when setting my valves that because there is a little slack in the cam chain, as you turn it the chain is tightening up to pull the cams against the springs in the valves. That basically pulls the camshafts down fully against the lifters. If I reversed the direction of the ctankshaft and rolled it back a bit, that allows slack in the chain going across the top. I noticed a couple of the valve clearances changed a little (like maybe a thousandth). I believe it's because the chain tension was released and it allowed the camshaft to rise up slightly because of the small amount of play in the cam bearing journals. I think to get both consistent readings and the TIGHTEST reading on clearance, you need to rotate the cam slowly and stop the cam without reversing direction. Not critical, but it gave me more consistent readings.
Last edit: 14 Jul 2008 12:07 by bountyhunter.
14 Jul 2008 12:05 #226112 by bountyhunter
Oh, it's one of those......:P
14 Jul 2008 15:38 #226133 by steell
Yep, and it's also one of those that rotate in the clockwise direction :)
The twins are the only ones that rotate counter clockwise (as far as I know anyway).
