clutch problems
  • jus1975
  • jus1975's Avatar Topic Author
  • www.tripleaperformance.com
clutch problems
13 Jul 2008 18:41
#225989
I have clutch problems. My clutch is feeling as if its hanging. You can let it all the way out and it hesitates then takes off. The cable, clutch, springs are all new. Any ideas whats wrong.
  • kzwolfsr
  • kzwolfsr's Avatar
Re: clutch problems
13 Jul 2008 21:22
#226011
You may need to check lubing in the clutch rod or the mechanism that operates the pushrod that is found in the sprocket cover
Original man of the Caribbean
  • KOOL RYDER
  • KOOL RYDER's Avatar
  • KZ 650B2 / KZ 1000E
Re: clutch problems
13 Jul 2008 23:12
#226016
loosen the nut at the handle and tune the spacer .
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
  • jus1975
Re: clutch problems
14 Jul 2008 09:07
#226070
What part are you refering too?
Re: clutch problems
14 Jul 2008 10:00
#226085
Extra! Extra! Read all about it!
Good Luck! :)
  • MFolks
  • MFolks's Avatar
Re: clutch problems
14 Jul 2008 12:47
#226119
I would suggest removing the clutch mechanisms cover(s) and look closely at how it operates. It is not uncommon to see play or looseness in the operation of the various pivot areas and maybe worn to the point of failure.
The shop manual is the first them I'd open up.
