Blown head gasket(updated with pics)
  • Tony
  • Tony's Avatar Topic Author
    Author
Re: Blown head gasket(updated with pics)
07 Sep 2008 10:28
#235967
Old Man Rock wrote:
Tony,
I purchased the same pipe (Kerker, yeah baby)...
Question, did you stick with the supplied baffle or did you upgrade?
I purchased the 1.5 competition baffle for mine but unfortunately, bike not up and running yet and have been wondering how loud this beast is going to be... I know, I know, poor old man Rock....
OMR
OMR, I stuck with the supplied baffle. I have yet to install the pipe. Still waiting on a couple of parts for it.
Your bike is looking great!! You must be getting anxious to get it on the road.
  • SLEEPER650
  • SLEEPER650's Avatar
10 Sep 2008 17:43
#236618
where did you buy the gunkote? do you know what all colors they have and what temp do you bake it at?
78 650sr my baby
78 650sr waiting for rebuild
82 kz1100
  • Tony
    Author
10 Sep 2008 17:59
#236620
If you look back about 3 post prior to this one you will see I posted that info there. Here it is again. You can get it from KG coatings here is a link to them.
click here for link
You cook it at 325 F for about an hour. If you check this link, click here you will find lots of info on how to put it on. Also, the suppliers of gunkote are very helpful and can give you all the info you need to do it properly. Good luck.
  • Tony
    Author
10 Sep 2008 18:03 - 10 Sep 2008 18:06
#236621
If you follow the link to kg coatings, then follow it through to the 2400 gun kote bake on link, then select that, there is a drop down list of all the colors they have.
Or you can click this link :D
Last edit: 10 Sep 2008 18:06 by Tony.
  • 79MKII
  • 79MKII's Avatar
  • Love Them Kaws!
11 Sep 2008 12:39
#236705
Looks awesome! Did you media blast with the pictured bench-top unit? I've been thinking about getting one but I'm not sure how well they work. What type of cfm are you flowing (air compressor, not bike!)?
The Kaw List:
  • Tony
    Author
11 Sep 2008 15:35 - 11 Sep 2008 15:44
#236733
Thanks 79MKII, I used that cabinet to do the valve cover. The head fit in there but it was a bit tight. If the hoses were longer in the cabinet it would have been doable. Instead I took it to work and used a bigger cabinet. The block was already clean when I received it. The air flow for that particular set up is 5cfm@80psi.
This cabinet works good but is a bit small. Bigger would be better, but I have limited space. Another member on this site, roynor, has a cabinet similar in size to this one. You might want to get his opinion. He seems to use his quite a bit.
Last edit: 11 Sep 2008 15:44 by Tony.
  • ran429
  • ran429's Avatar
  • Master of FREE rides!
13 Sep 2008 05:54
#236957
i wish i would have known about this gunkote stuff when i did my last rework on the 750. that would have made the parts i painted look great!
Maybe i will have a nice work space at the new house we buy here soon. Never again to be without a work bench.
Craigslist oven and all.
  • Tony
    Author
13 Sep 2008 09:14
#236981
Randy, Nice job on the 750. It looks great. :)
Good luck on the new house. :) Make sure to post some photos.
