Just did Compression check scared at first
- volsrock
Thought that may be a little low at first.
But engine was cold and I didn't open up the throttle at all.
I am not going to recheck cause done put plugs back in
And everything I read on here says it will go up quite a bit with the throttle open.
- steell
That would probably be around 170 if you tested warm with wide open throttle.
I wouldn't bother retesting it either
- volsrock
- CoreyClough
- GPz550 Addiction
- Thank you received: 80
'85 GPz550(ZX550-A2)
- bountyhunter
- Thank you received: 337
Just check Compression on my 81 kz750 had 120 on all 4
I did that test a couple of weeks ago. I think mine went up maybe 30 - 40 psi from spinning with throttle fully closed to fully open. Sounds like yours are right on the money.
- volsrock
- volsrock
- The Gringo
- ¡Usted no necesita otra motocicleta!
- Thank you received: 11
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
