- Thank you received: 4
kz650 Shifting Issues/Question
- KawiConvert
12 Jul 2008 14:24 #225743
by KawiConvert
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
kz650 Shifting Issues/Question was created by KawiConvert
I am trying to shift my bike while it is not running and I have found that I can shift into first and back to neutral, but I cannot shift to second. I have tried kicking the engine over or rolling the bike but nothing seems to work. Is this common or is there something that I should look at in the transmission? Again, this is without the bike running.
Thanks,
KC
Thanks,
KC
- SPARKY47
- 1980 KZ500 B2
- Thank you received: 5
12 Jul 2008 15:17 #225753
by SPARKY47
1980 KZ500 B2
Replied by SPARKY47 on topic kz650 Shifting Issues/Question
There is a system on these bikes which prevent you from shifting into 2nd gear or higher when the bike is stationary.:woohoo:
1980 KZ500 B2
- KawiConvert
12 Jul 2008 20:10 #225789
by KawiConvert
Replied by KawiConvert on topic kz650 Shifting Issues/Question
SPARKY47 wrote:
Thanks, that is good to know. I was starting to worry that I may have messed something up or worse, bought a bike with a bad transmission. I'll have to get it all back together.
- Bluemeanie
- Thank you received: 14
13 Jul 2008 06:14 #225835
by Bluemeanie
Replied by Bluemeanie on topic kz650 Shifting Issues/Question
It's called Kawasaki's exclusive neutral finder (or something close to that) when wheel (gears) are not turning it will not go past neutral. Works great, downshifting as you come to a light or stop sign, down to first and come to a stop. One click up and your in neutral, no more hunting for it.... works great! I see my friends looking for neutral while I'm idling waiting for the green light.
- KawiConvert
13 Jul 2008 12:58 #225928
by KawiConvert
Thanks for the info behind it. I am glad that it was intentional rather than some design flaw that they found afterwards. I was also worried that my rearsets just didn't have enough travel or leverage to properly shift it.
KC
KC
- kzwolfsr
- Thank you received: 16
13 Jul 2008 14:02 #225935
by kzwolfsr
Original man of the Caribbean
Replied by kzwolfsr on topic kz650 Shifting Issues/Question
No way man. These bike were well engineered without ECU's or useless electronics. All mechanical
- KawiConvert
13 Jul 2008 15:53 #225956
by KawiConvert
Last bike I rode I found neutral fairly easily...
but it was generally while trying to shift into second.
*Ba* *Dum* *Bum* *Bing*
"Thank you, thank you, I'll be here all week!"
There is something nice about a well designed mechanical system.
