question on compression
- xblesseddeadx
12 Jul 2008 08:00 #225692
by xblesseddeadx
question on compression was created by xblesseddeadx
Hey does anybody know what the compression should be ( in psi) for a 78 kz650 SR?
- Bluemeanie
- Thank you received: 14
12 Jul 2008 08:14 #225697
by Bluemeanie
Replied by Bluemeanie on topic question on compression
According to my FSM it should be "156-185 psi with minimum of 114 psi and less than 14 psi difference between cylinders".
- CoreyClough
- GPz550 Addiction
- Thank you received: 80
12 Jul 2008 08:49 #225703
by CoreyClough
'85 GPz550(ZX550-A2)
Replied by CoreyClough on topic question on compression
I see Bluemeanie's reply and raise you:
-Warmed up engine
-All spark plugs removed
-Battery completely charged
-Throttle wide open during testing
I'd do it twice, and the second time, add a little oil in the cylinders and make notes of the compression changes.
If you haven't made sure the valves are within spec, you could have a tight valve, and that would throw the readings off. A large valve clearance wouldn't make a difference on a compression test, unless it's a stuck open valve.
Do us a favor, and put your readings here.
-Warmed up engine
- xblesseddeadx
15 Jul 2008 19:50 #226390
by xblesseddeadx
Replied by xblesseddeadx on topic question on compression
my readings were 126, 118, 112, and 120. seems to me like that should be ok.
- steell
16 Jul 2008 04:38 #226439
by steell
Replied by steell on topic question on compression
xblesseddeadx wrote:
One below service limits and a greater than 10% difference between any two cylinders doesn't sound "ok" to me.
I think you should check/adjust the valve clearances then retest.
