cylinder bore specs
  • donthekawguy
  • donthekawguy's Avatar Topic Author
cylinder bore specs
09 Jul 2008 01:53
#225084
I'm going to take my cylinders to a machine shop this weekend and need to know what the specs are for out of round and what the max size is. BTW it's for a 1075. Someone posted the three measurments on here a while back but I couldn't find them. Also if you have the ring gaps handy that would help a ton since I'm getting a new set of rings soon.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • bountyhunter
  • bountyhunter's Avatar
Re: cylinder bore specs
09 Jul 2008 12:58 - 09 Jul 2008 12:59
#225189
If you mean ring end gap installed in the cylinder, the nominal value is about .003 -.004" PER INCH OF BORE DIAMETER.
I was surprised to find that on mine the service limit for end gap is DOUBLE the nominal value. It's not a critical spec, unless it's too tight which could cause a ring to break.
Last edit: 09 Jul 2008 12:59 by bountyhunter.
  • donthekawguy
10 Jul 2008 02:03
#225292
Thanx that'll work for the gaps now I just need the specs for the cylinders. Anyone, anyone?
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
  • APE Jay
  • APE Jay's Avatar
10 Jul 2008 09:31
#225343
Wiseco, JE, or MTC?????
  • bountyhunter
10 Jul 2008 12:35
#225370
If you accurately measure the piston diameter, you can calculate the allowable bore dimensions. When I took mine in to the machine shop to be bored, they insisted on having the pistons to size from.
  • donthekawguy
10 Jul 2008 23:18
#225472
You know, I never checked to see what brand they are. I got them as a set of pistons, rings, pins and cylinders off ebay about a year or so ago. Maybe I should look into it before I start having any work done. ;)
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
