top cam chain dampers
- jbrewer73
08 Jul 2008 20:06
I have a 77' KZ1000.
Is the cam chain idler supposed to have any movement after tightening down? Mine are tight but if I apply pressure on the idler it rocks a hair. I have the valve cover off to adjust valve clearance and wabt to know if the two dampers need replaced.
Thanks
Thanks
- Sandy
- Fly High,Tony
Re: top cam chain dampers
08 Jul 2008 20:20
Are you talking about the top tower?
There will be a tad of movement there,but if it's sloppy,get rid of it now.
Rereading your post,are you saying that the top tower BRACKET moves when it's tightened down?
1977 KZ1000 A-1
- jbrewer73
09 Jul 2008 05:34
Yes its the top tower. The dampers actually look pretty new but just a hair of movement. Based on wjat you just said I think I am fine.
Thanks
Thanks
- Sandy
- Fly High,Tony
09 Jul 2008 07:11
If it's the sprocket that has a bit of play,that's one thing,but if it's the bracket that has movement,that's NOT good.
Which is it?
Which is it?
1977 KZ1000 A-1
- jbrewer73
09 Jul 2008 08:09
It is the bracket. I have new dampers already. Maybe I should just replace them Huh?
- Sandy
- Fly High,Tony
09 Jul 2008 17:36
You have brand NEW dampners?
Doesn't make sense,why you can't tighten that tower down.
What do the 4 bolts look like...can you post a pic of the whole thing,or at least the bolts and what type of head on the bolts.
I wonder if maybe a P.O. used longer bolts at one time,or even the wrong tower...one from a different model KZ.:huh:
1977 KZ1000 A-1
- jbrewer73
10 Jul 2008 09:50
Hey Sandy,
Sorry for the confusion but what I meant was I have a brand new set uninstalled that i could put in. I noticed that my sprocket has some play too but they want between 80 and 100+ for a new one from Z1. I hope ht elittle play i see is normal for the sprocket. I am going to replace the dampers though.
