oil?
- jdreadrocker
83'GPZ750-r1
Bald Knob, Arkansas
other bikes owned:
72 honda cb500, 2003 Buell Blast P3
- racer54
- Thank you received: 114
- NickW900LTD
- Nick
1976 KZ900 LTD (sold)
1977 KZ1000 LTD
1978 KZ1000 A2A
Pierceton, Indiana USA
- Bullitt03737
1980 CSR 1000. New dyna Coils, Vacumn Less Petcock, Various Handle bars depending on the day, (Drag and Clubman.)
- RonKZ650
- Thank you received: 240
- MFolks
- Thank you received: 540
- Saki Jockey
Rob A.
550 A4
GTA,
Ontario, Canada
- kzwolfsr
- Thank you received: 16
Original man of the Caribbean
- RonKZ650
- bountyhunter
- Thank you received: 337
Back in the 80's, Castrol GTX 10-40 was the only oil that dealer's put in new bikes or bike's they serviced around here. It's very good oil and has high resistance to viscosity breakdown from shear effect. There may be better oils now, but it's still pretty good.20w-50 castrol gtx.
I still would not run any conventional oil in a bike more than about 2000 miles because of the gearbox shearing the viscosity enhancers turning 10-40 oil into 10W oil.
As for viscosity: 20-50 is good for hot weather only, 10-40 is good for cool weather, you can also mix it for 15-45W. Avoid any oil with "energy saving" on it because it has friction reducers that may gum up your clutch. Most 10-30W oils have this in them.
Here is a reference site on oil:
www.calsci.com/motorcycleinfo/Oils1.html
- bountyhunter
Some of the references I have read say the "diesel specific" oils use higher grade viscosity enhancers which are more resistant to shearing effect, to enable the oil to run in trucks for very long service periods. That makes them ideal for motorcycle service. These additives also cost a lot more, hence the higher price of the oil.I went to Shell Rotella-T 15w40. 15w40 is a diesel engine viscosity and I've used it in the diesel trucks for 20 yrs.
- kzwolfsr
