oil?
- jdreadrocker
oil?
08 Jul 2008 14:59
i know this is going to be a dumb question but what type of oil do you use in a GPZ 750? 10-30? 10-40? Does it matter?
83'GPZ750-r1
Bald Knob, Arkansas
other bikes owned:
72 honda cb500, 2003 Buell Blast P3
Bald Knob, Arkansas
other bikes owned:
- racer54
Re: oil?
08 Jul 2008 15:58
I have no idea what the answer to your question is, but.....there are no dumb questions around here. Only dumb mistakes because the question wasn't asked first.
- NickW900LTD
- Nick
Re: oil?
08 Jul 2008 17:06
20w-50 castrol gtx.
1976 KZ900 LTD (sold)
1977 KZ1000 LTD
1978 KZ1000 A2A
Pierceton, Indiana USA
1977 KZ1000 LTD
1978 KZ1000 A2A
- Bullitt03737
Re: oil?
08 Jul 2008 17:06
Does it not have something cast into the oil filler hole cap?
1980 CSR 1000. New dyna Coils, Vacumn Less Petcock, Various Handle bars depending on the day, (Drag and Clubman.)
- RonKZ650
Re: oil?
08 Jul 2008 18:23
They always recommended 10w40. You can use 20w50 but not in cold weather. I told my story about Castrol GTX in that I religeously change oil every 2000 miles, plus I was burning a quart of oil every 400-500 (165,000 mile KZ, worn
) So that's 8 quarts of "fresh Castrol" every oil change. You know what weight my 10w40 was in the end? Good question because I don't either. Removed the drain plug to drain, 2 oz of 90wt gear oil oozed out and that was it, rest was too sludged to even drain out. I have a couple cases of GTX sitting in the garage and I will not ever use it again. I guess just like when you get sick you think of the last thing you ate when in reality that is probably not even what it was. I think of the oil. This engine got real sick real fast.
- MFolks
Re: oil?
08 Jul 2008 18:46
I've only used the Bel-Ray 10w40 oil in my 82 GPZ1100 B2 with no problems (3000 miles between oil and filter changes).
- Saki Jockey
Re: oil?
08 Jul 2008 18:56 - 08 Jul 2008 18:58
Esso 15W40, without the fuel conserving additives. I've used it in every bike I've owned without problems. Change oil more on time than mileage, 2 to 3 times per year (less than 2k per change)
Rob A.
550 A4
GTA,
Ontario, Canada
550 A4
GTA,
Ontario, Canada
Last edit: 08 Jul 2008 18:58 by Saki Jockey.
- kzwolfsr
Re: oil?
08 Jul 2008 18:58
Yippeeeee another oil thread. I religiously use valvoline on my vehicles. 10w40 on my jeep cherokee and 20w50 on my 1000. Haven't found any probs with sludge especially with 3000 mile oil changes almost like you Ron! What brand do you use Ron?
Original man of the Caribbean
- RonKZ650
Re: oil?
08 Jul 2008 20:36
I went to Shell Rotella-T 15w40. 15w40 is a diesel engine viscosity and I've used it in the diesel trucks for 20 yrs. So far it's worked great in that KZ650 I ride to work with 62000 miles on it. I got some valvoline 10w30 I'm using next Winter though as 15w is too thick in Winter riding at 10 degrees as I'm not driving that diesel anymore needless to say if at all possible.
- bountyhunter
Re: oil?
08 Jul 2008 21:23 - 08 Jul 2008 21:28
NickW900LTD wrote:
I still would not run any conventional oil in a bike more than about 2000 miles because of the gearbox shearing the viscosity enhancers turning 10-40 oil into 10W oil.
As for viscosity: 20-50 is good for hot weather only, 10-40 is good for cool weather, you can also mix it for 15-45W. Avoid any oil with "energy saving" on it because it has friction reducers that may gum up your clutch. Most 10-30W oils have this in them.
Here is a reference site on oil:
www.calsci.com/motorcycleinfo/Oils1.html
Back in the 80's, Castrol GTX 10-40 was the only oil that dealer's put in new bikes or bike's they serviced around here. It's very good oil and has high resistance to viscosity breakdown from shear effect. There may be better oils now, but it's still pretty good.20w-50 castrol gtx.
Last edit: 08 Jul 2008 21:28 by bountyhunter.
- bountyhunter
Re: oil?
08 Jul 2008 21:31
RonKZ650 wrote:
Some of the references I have read say the "diesel specific" oils use higher grade viscosity enhancers which are more resistant to shearing effect, to enable the oil to run in trucks for very long service periods. That makes them ideal for motorcycle service. These additives also cost a lot more, hence the higher price of the oil.I went to Shell Rotella-T 15w40. 15w40 is a diesel engine viscosity and I've used it in the diesel trucks for 20 yrs.
- kzwolfsr
Re: oil?
09 Jul 2008 06:30
Makes sense!
