Cylinder Studs, Gasket Sealers, and Cam Chain Questions
  • Tony
  • Tony's Avatar
    Author
Re: Cylinder Studs, Gasket Sealers, and Cam Chain Questions
18 Jul 2008 11:38
#226908
Glad to hear everything went well for you. It sounds like I'm going through the same thing as you right now. I'm just waiting on some cam chain tensioner parts, a new set of 1075 pistons and block and some black gunkote to finish it with. I haven't had a chance to get back to those cylinder studs yet. They must be locktited in. I have a new set of ape studs to replace them with.
  • NormZ
  • NormZ's Avatar Topic Author
18 Jul 2008 14:51
#226945
Here's a few pictures from before the rebuild...
  • NormZ
18 Jul 2008 14:52
#226946
  • NormZ
18 Jul 2008 14:53
#226947
  • NormZ
18 Jul 2008 14:53
#226948
  • NormZ
18 Jul 2008 14:57
#226950
And now a couple of after pics...
  • NormZ
18 Jul 2008 14:57 - 18 Jul 2008 15:01
#226951
No fresh oil on the floor:cheer:...But you can still see the old stains.
Last edit: 18 Jul 2008 15:01 by NormZ.
  • Tony
  • Tony's Avatar
    Author
18 Jul 2008 15:23
#226956
Looks good!:)
  • wiredgeorge
  • wiredgeorge's Avatar
18 Jul 2008 17:13
#226977
When I remove engine studs, I use stud puller and when I intall them, I use a stud install tool. I think APE actually sells both tools. There are different types of pullers and some work better than others... some will damage thread easily. I wouldn't loctite them... I also use NAPA brand gasket sealer. When it dries it makes the gasket hold oil a whole lot better... I don't use it on the head gasket but all the cover gaskets and the base gasket.
