Before I remove anything else....
  • BeeSting
  • BeeSting's Avatar Topic Author
  • Drive it like your tax dollars already paid for it
06 Jul 2008 04:47
#224352
The engine cover on the left side of the bike (as seen when you're sitting on it), what is it and can it be removed without dumping oil or anything? I'm referring to the cover with "Kawasaki" written on it.
I'm redoing the Kawasaki writing all over the bike. I already did the right side with very good results.
Thanks
BeeSting
Flint, Michigan - Chicagoland, IL
If I wasnt such a badass American, I would have to drive a Harley to make up for it
1980 Kawasaki KZ750 H1 LTD (4)
Kurayami (Girl of Darkness)暗闇の女
1980 Honda CX500C - GONE
Christine
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: Before I remove anything else....
06 Jul 2008 05:05 - 06 Jul 2008 05:15
#224357
Well, that is the right side of the bike and that is the point/pickup coil cover...safe to remove w/out oil loss. Salvage the gasket:)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Last edit: 06 Jul 2008 05:15 by Mcdroid.
  • BeeSting
06 Jul 2008 05:28
#224362
Thank, but I was showing a picture of the work I've done so far. So I need to know what is on the left side
BeeSting
Christine
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
06 Jul 2008 05:39 - 06 Jul 2008 08:52
#224365
Ah, then, yes, you'll lose oil (but not much) as that is the stator cover...why don't you paint it by hand (in place) then you don't have to worry about oil issues and on that one, you should replace the gasket...
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Last edit: 06 Jul 2008 08:52 by Mcdroid.
  • Bluemeanie
  • Bluemeanie's Avatar
06 Jul 2008 06:01
#224369
For some reason the 1000/1100's seem to have oil under the stator cover (normal?) My 650 and others have always been dry as a bone under there (normal?). I would think the same for your 750 as they are the same engine. I guess it's just a big block thing... ;)
  • BeeSting
06 Jul 2008 15:52
#224489
Well I took off the right one and went to town with some nevr dull and then masked it off and painted it. I think I'll be able to do a better job with it off.
Is there supposed to be oil in there (on the left)or is that just something that happens? I figured there was some difference because it has 4 fasteners instead of the 2 that the right has.
BeeSting
Christine
  • HerrDeacon
  • HerrDeacon's Avatar
06 Jul 2008 16:44
#224505
The stator on my 650 is totally dry, no oil. However, I have heard that some KZ's do leak a bit of oil in there. You should be able to take it off no problem.
BTW, nice job on the points cover.
  • BeeSting
06 Jul 2008 19:40
#224545
Cool, thanks and thanks.
I thought the nevr dull would do a better job. I had some left over at the armory from the memorial I built for the guys our Batallion has lost over the past few years.
It did end up looking a little better and then I used a dremel (black and decker version) to polish it a little more (using the "juice" from the Nevr dull and a little bit of car polishing paste).
After it was done I used (sacraficed) one polishing bit for removing the paint from the "Kawasaki" and then I buffed those letters a bit.
BeeSting
Christine
  • coppertales
  • coppertales's Avatar
07 Jul 2008 09:16
#224636
Flitz, or something like that, is a better polish compound. You can get it at most hardware stores.....chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
  • BeeSting
07 Jul 2008 13:30
#224699
Well I got in there but at the expense of two of the screws. Had to drill the heads off them.
Its too bad Kawasaki didn't think of using steel inserts for the threads.
There wasn't any dirt or oil inside the cover.
BeeSting
Christine
