1976 KZ900-A4 OEM CAM Lift Duration???
- Old Man Rock
05 Jul 2008 08:12
Hey all,
Researching which CAM's I want to go with and I can't for the life of me (Googled) nor in the Kawasaki Shop Manual find the cam lift duration specifications on the OEM camshafts...
Gears are 30 tooth sprocket with 122 link chain...
Anyone know?
I only want to use as a comparison... .365, .384, .395 or .410's. What to do, what to do...
Thanks,
Old Man Rock
Anyone know?
Thanks,
Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- martijn
Re: 1976 KZ900-A4 OEM CAM Lift Duration???
05 Jul 2008 13:13
exhaust 0.296 lift and 229 degrees
0.327 lift and 237 degrees intake
- PLUMMEN
05 Jul 2008 17:10
any of them would be an improvement.just remember the bigger you get the more other weaknesses are going to show up.
- nads.com
05 Jul 2008 22:06
martijn wrote:
at what valve height and what lash setting? Im not sure but though they had 280 at zero lash from ope to close. WEven more cnfsd nw.exhaust 0.296 lift and 229 degrees
