Exhaust Studs Vs Bolts
- BigBlockT
04 Jul 2008 20:47
was wanting to change my exhaust studs on my z1-900 to allen head bolts is that possible and if so can I use stainless?
- kawsakiman
Re: Exhaust Studs Vs Bolts
04 Jul 2008 21:09
good question.
i don't see why not. the only problum i would worry about would being able to draw them up tight enough to prevent any leaks.
anyone here ever do this ?
- MFolks
04 Jul 2008 21:36
If the bolt in question is an M8x 1.25 size then a company called ARP has your answer. try them at
www.arp-bolts.com/catalog/catalog
The studs come in four lengths and are stainless steel with a tensile strength of 170,000PSI and are available in 4,8,10 and 16 packs.
The specs are:
M8x1.25x32MM (1.250") #400-8011
M8x1.25x38MM (1.500") #400-8012
M8x1.25x45MM (1.750") #400-8013
M8x1.25x51MM (2.000") #400-8014
M8x1.25x57MM (2.250") #400-8015
The studs come with easy start 12 point SS nuts
The specs are:
- MFolks
04 Jul 2008 22:02
Also studs will last far longer than installing and removing bolts that will deform/destroy the threaded holes in the aluminum head.
- wiredgeorge
05 Jul 2008 08:21
The studs on a Z1 engine are M6... I think an M6 1.0 pitch about 45mm long would be right... the length is from memory and I wouldn't use one that is shorter than the OEM. I also suspect that I would prefer using studs as there won't be much mechanical holding power if using bolts; only lockwashers to my way of thinking and they will not hold well. The stainless will also tend to gall to the aluminum head and I can see thread issues.
- rstnick
05 Jul 2008 09:50
I'd think installation of the exhaust is easier with the studs as you can slip the exhaust collers over the studs, helping to line everything up and support the exhaust.
If you used bolts, you have to find each hole, be careful of cross-threading, and be in and out of the threaded holes many times over the years where as the studs have been in my head since day one, giving less chance for wear compared to using bolts.
Just an opinion.
Just an opinion.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- BigBlockT
05 Jul 2008 14:27
after all this advice I will just stick with the studs. thanks guys.
