help
- skullroses
02 Jul 2008 19:06 #223608
by skullroses
1982 kz750 LTD
help was created by skullroses
my bike will not turn over w/o playing with the throttle, and will not start when hot ???
1982 kz750 LTD
- steell
02 Jul 2008 20:08 #223633
by steell
Replied by steell on topic help
Have you ever done a complete tune up on it, including checking the valve clearances?
If not, then that would be a good place to start.
- baldy110
- Thank you received: 512
03 Jul 2008 09:10 #223739
by baldy110
Replied by baldy110 on topic help
By not turn over do you mean the starter won't engage? If that is so it sounds like you have a short in the starter button switch assembly. When you wiggle the throttle it temporarily fixes the problem.
- skullroses
04 Jul 2008 17:42 #224080
by skullroses
1982 kz750 LTD
Replied by skullroses on topic help
how much will i expect to spend if I have a dealer tune up my bike? I filled up and I've used half a tank in 30 miles!
I've only been riding less than a week and never had it over 55 mph. :S
1982 kz750 LTD
- bountyhunter
- Thank you received: 337
04 Jul 2008 22:36 - 04 Jul 2008 22:38 #224155
by bountyhunter
Replied by bountyhunter on topic help
skullroses wrote:
You must have raw gas running out of it to do that. You should check the fuel levels in your carbs.
I'd vote for starters:
1) Drain and flush fuel tank.
2) Change or install inline fuel filters.
3) Adjust fuel levels in carb bowls.
4) Check valve clearance is a good move, also cylinder compression.
how much will i expect to spend if I have a dealer tune up my bike? I filled up and I've used half a tank in 30 miles!I've only been riding less than a week and never had it over 55 mph. :S
Last edit: 04 Jul 2008 22:38 by bountyhunter.
- The Gringo
- ¡Usted no necesita otra motocicleta!
- Thank you received: 11
04 Jul 2008 23:19 #224167
by The Gringo
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Replied by The Gringo on topic help
Mike, on Monday I'll try to do some troubleshooting and take it for a ride. The weather is supposed to be good on Monday. We'll do a compression test and also check the coil voltage, although the spark looked good on Thursday.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
