- Thank you received: 16
Split Cases and replace parts for the F^@$ of It...
- mtkawboy
- PLUMMEN
- Thank you received: 104
- Old Man Rock
- Thank you received: 225
Nope, too old for that any longer... Will I get on her here and there, well ya but nothing enough to make me piss myself...if you plan on hot rodding it
Nose wheelies, uhm NO, makes poopy pants.... Me no like poopy pants... :woohoo:
Ok, since all ready have them open, bearings, all CAM related parts (sprockets, chain, guide, idler, tensioner etc...), any screwed up tranny gear or shift fork of course, seals and main bearing, heavy duty cylinder studs(YES)and main bearing studs (possibly)...
Seems to be quite a list... Dad to daughter, Sorry honey, no college for you, need bike parts!
Thanks all,
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- mtkawboy
- Old Man Rock
I really don't feel it but you know, it's the way it goes.
I don't heal the way I use to so I'll be cool with going 60-80mph cruising on a nice strong motor. When needed (Harley or some other ass wipe (Jap bike included)), open her up and leave them wonder WTF just happened.
Other than that, no poopy pants.... See a theme here...lol!
OMR
To place a face with a name...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- mark1122
- Keep twisting it
- Thank you received: 109
sounds like u have found all the week spots.
1.trany.only weak spot is the shift forks. they can get bent or warn and cause miss shifts or come out of gear. if it shifts good now they should be fine.
2.cam rollers and guides. they can work fine now but there rubber will be hard and dried up and a good candidate for failure.cam chain guides like to break.
3.cam chain. have to split the cases to do this right.imo.u can use a cheeter link hear but that is up to u.
4.oil pump.not likely to fail but slowly ware.take it apart and measure all clearances. then come back for advice from the guys hear.
5. bearings. pretty tough .dont usually go but u never know.
6.crank.should be fine .if u are going 1100cc or launching it ,welding would be recommended.main bearing plate and studs is to reduce crank twisting when launching at the drags with big cc motors and big tires.main bearing cap must be machined.
7.clutch basket.the springs in the back of basket get week and loose .then they break and add a little extra viscosity to the oil.u have to break the cases to inspect them.APE sells a kit to replace them.I can help u hear if needed. been there done that.
8.head. Valve seals ,guides ,valve job,springs. only if needed.u can replace the seals and springs easily with minimal tools. u need to make 1 tool though. pmp me if u do this.
9.heavy dudy cyl studs are recomended if u raise the compresion . this allows u to torque the head tighter.40ft.lbs.
10.what else guys?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- PLUMMEN
main bearings?have you looked at how the crankshaft is put together?:laugh: i wouldnt get all excited about heavy duty studs and all that stuff.i realize APE JAY makes money on that stuff but im sure he would rather make money selling you parts you really need which tends to lead to a return customer rather than a one shot deal.i will retire to my basement now as Jay turns his death ray on nebraska!but i might add if APE did actually have a deathray it would be the worlds fastest!:woohoo:Nope, too old for that any longer... Will I get on her here and there, well ya but nothing enough to make me piss myself...if you plan on hot rodding it
Thanks all,
OMR
- kawsakiman
- Thank you received: 6
better to have it done and never need it then be without it in case you decide to go with bigger cams later.
the list is long on what you can do now in case you decide to up the ponies later.
maybe convert it to shim on bottom now also?
and ape cylinder studs are cheap insurance imo.
- Old Man Rock
Yep, if required...
I'm still debating on which cam I'm going with but I'm fairly sure I'm sticking with the following from Dynoman.
118 .365 283° Performance street cam for stock engines. Stock base circle. 60-082 new cam $329.95
They also have a .395 version but hell at this point might as well go with the K410's.
Based on my age, riding style and such I believe the .365 will be a more suitable fit for me. Strong motor, will get up and go when asked but not so in your face aggressive... I'll leave that to the youngsters here in the forum.
Again, me no like poopy pants! :X
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- OLTIMER
- Back when I was your age, ...
Hey, I resemble that remark! :blink:Too old ????? Ive got a 64 year old body and a 20 year old brain, thats a 42 average right ? Crap even thats old !
@ OMR - Best luck with the rebuild - let us know what you find, eh?
Peace,
-OlTimer
1978 KZ650-D1 SR
Sioux Falls, SD, USA
The shortest distance between two points is under construction.
- Old Man Rock
I'll just measure the damn thing and see what I come up with... CAM Height (heel of cam to nose) - Base circle...
Here's what I found...
119 .384 276° Street or turbo.
Broad overall power range. Stock base circle.
60-242 new cam $329.95
110 .395 284° Good mid range and top end power for hot street. Use with big bore pistons and performance valve springs, available separately. Stock base circle
60-092 new cam $329.95
Then of course... :evil:
K410 .410" LIFT 266deg. Duration @ .030"
Hot street and strip thru 1100cc. Great road-race grind. Best all-around cam available for 1015/1075cc motors. APE valve springs required. Top shims okay. Will not work with stock pistons. Std (1.110") base circle. One of the most popular Kawasaki cams ever sold. $389.95
As can be reviewed, just need to figure out based on my riding style what I'm really looking for.
Questions to the KZ gods and guru's....
"Use with big bore pistons and performance valve springs"
I understand the need for the stronger springs but BIG bore pistons/Will not work with stock pistons? My Wiseco 1015cc kit is on the way so does this fit this profile/remark?
If I grow some balls and go with the K410, special grind/modification to the head required?
Oh decisions, decisions....
In you face raped ape or strong but not pull you off the damn bike....
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- mtkawboy
