'nother oddball question
  • Beepy
  • Beepy's Avatar Topic Author
01 Jul 2008 20:40
#223415
So some of you might have been following my little problemma with the friggin oil light... Well I have finally got that running however....
On remounting the exhaust I seemed to have not noticed that two of the copper seals fell out. I have the exhaust bolted on tight with the shims in place, it just sounds like a harley now :blink:
I really don't mind this throaty sound much, its just I am planning a 300 mile road trip in two days and am wondering if this will screw things up? I heard about a guy that blew his engine cause did a test run while neglecting to bolt the exhaust back on after a rebuild. Just a bit nervous...
Thanks!!!
  • cmmman
  • cmmman's Avatar
Re: 'nother oddball question
01 Jul 2008 22:04
#223426
:ohmy: That would be enough for me to put the gaskets in there. B)
1977 KZ650B, modified.
  • Bluemeanie
  • Bluemeanie's Avatar
02 Jul 2008 05:32
#223461
It won't really hurt anything as the leak is small. But the sound would drive me nuts so I would just fix it, not a hard job. You'll be glad you did... :)
  • baldy110
  • baldy110's Avatar
02 Jul 2008 08:37
#223490
The exhaust leak will eat away at the softer aluminum head causing a sealing problem later if left unfixed. I would say 300 miles would do some damage. I would fix it before the trip.
  • mtkawboy
  • mtkawboy's Avatar
02 Jul 2008 08:46
#223493
I have a Harley and it does not sound like one, it sounds like crap. Fix it, only takes about an hour to drop them and do it right
  • riverroad
  • riverroad's Avatar
  • 1980 1000LTD B4
02 Jul 2008 09:06
#223495
Not only can it cause erosion of the sealing surface over time, it can also allow oxygen into the exhaust port, which can cause your exhaust valve to burn.
At least that's what they used to tell me way back in Airframe and Powerplant school.
  • Beepy
02 Jul 2008 11:58
#223523
OK.. Ok I dropped 'em and put some new seals in.... now I know my cam chain is clanking a bit.... gotta check the tensioner. I dont trust the automatic tensioner....
  • steve3408
  • steve3408's Avatar
02 Jul 2008 20:22
#223641
So what did you do to fix your oil pressure/light problem?
Inquiring minds want to know....
1980 KZ1000 A4(bought new),1979 KZ1000 MKII(bought new),1978 KZ1000 A (sold)1979 KZ1000 B LTD (sold)1976 KZ900 LTD (sold)1978 KZ750 twin (sold)
  • OLTIMER
  • OLTIMER's Avatar
  • Back when I was your age, ...
04 Jul 2008 08:30
#223936
Follow the steps here to perform the adjustment for can chain tensioner.
1978 KZ650-D1 SR
Sioux Falls, SD, USA
The shortest distance between two points is under construction.
