Friggin' Oil!!!! *Update #2 - WOOT!- *
30 Jun 2008 20:48 - 01 Jul 2008 20:35 #223208 by Beepy
Ok, last year after I rebuilt the top end of my '99 KZ1000P and put an Emgo oil filter and ran 20W-50. My oil light would always go on after it warmed up at idle speeds. Bugged the heck out of me cause I was always worried about the low oil pressure in these things to begin with....
This last Febuary I had it de-winterized at my local shop and have been riding it since then with no problems, ie no oil light problems when sitting at a stop light or anything.
Well today I changed the oil, and cause I am going to be doing a road trip here this week I put in another Emgo filter I got from Z1 and filled it with 20W-50. I ran it for awhile and then topped it off so the oil filling window is filled. Well now when its warmed up the oil light problem is back at idle! UURRGGHH The only thing that I can think of that has changed is that there is a problem with the filter or the weight of oil. Is there something special that you have to do to these filters. I just pulled the old one off and put the new one on and screwed it back in. I was then thinking that maybe the heavier weight of oil was not going through the filter correctly, but then I would get the light when the engine is cold not after it has warmed up (the light is off at idle speeds with a cold engine).
Any ideas? I have to leave the day after tomorrow!!!!
Last edit: 01 Jul 2008 20:35 by Beepy.
30 Jun 2008 21:06 #223214 by The Milkman
Replied by The Milkman on topic Friggin' Oil!!!!
Call the local shop and ask what brand filter and what weight oil they used.
01 Jul 2008 07:33 #223285 by wiredgeorge
Replied by wiredgeorge on topic Friggin' Oil!!!!
The oil filter was likely installed incorrectly. See the kawasaki.com parts diagram for the order that the washer and spring go onto the part that screws into the engine cases.
01 Jul 2008 08:52 #223293 by mtkawboy
Replied by mtkawboy on topic Friggin' Oil!!!!
Sometimes the old rubber washer will get stock up in there. Reach up top of where the filter goes and make sure there isnt an old one there. Do you recall if you had 2 rubber washers off the old one when you changed. Yesterday I had to do the excact same thing on mine, one washer stayed up inside.
01 Jul 2008 12:50 #223332 by Beepy
Replied by Beepy on topic Friggin' Oil!!!!
Well, I checked for washers... we are good there. Called the shop and they use 10W-40 so I put the old filter back in (it really didn't need changing in the first place) and refilled with 10W-40. Now the stupid light comes on at about 1,800 RPM instead of idle!!!! UUUUURURRRRRRRRGGGGGGHHHHH!
01 Jul 2008 14:34 #223345 by Sandy
Replied by Sandy on topic Friggin' Oil!!!!
I see there's a few more parts involved in the "P" model KZ's,as opposed to the older models.
On the oil-filter bolt,I see a small spring and a check-ball.
Are you sure that ALL of these parts are there?
Take a look...
1977 KZ1000 A-1
01 Jul 2008 14:38 #223346 by Sandy
Here are the part descriptions...
1977 KZ1000 A-1
01 Jul 2008 16:20 #223358 by Vter Bob
Replied by Vter Bob on topic Friggin' Oil!!!! *update-still broke!*
I always run Castrol 20W-50 and will use nothing else but a Wix filter. Never ever had a problem. For sure, don't use the "orange" ones.
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
1999 ZG1000 Concours
Greetings from the Peoples Republic of Vermont, home of Ethan Allen, 2 American Presidents, a socialist US Senator and.....Homer & Bart Simpson
01 Jul 2008 20:34 #223412 by Beepy
Replied by Beepy on topic Friggin' Oil!!!! *update-still broke!*
Well.... Its been a day! For kicks I pulled the reservoir plug while it was running. Oil just seeped out, I guess the light was right and I really had very little pressure! I ended up pulling the oil pan and oil pump off then tearing the oil pump apart. I did not see anything really wrong, honestly the pump looks brand spakin' new! I lucked out an had an extra oil pan gasket from the rebuild last year (I also used a bit of hi-temp liquid gasket -- but not alot -- just something I learned through some bad experience!)
I threw the whole shamdangle back together (that exhaust is a PITA!) and the light is now off! WOOT
Now the only problem I have is that it seems the little copper seal on one or two of the exhaust brackets fell out and I bolted everything back together without them. She sounds a bit throaty now! Now my question is, will missing one or two of those copper seals screw-up my engine? I heard about a guy that blew his engine cause he test ran it without bolting on an exhaust after a rebuild. Now the exhaust is bolted on tight with the shims in place, just two of those copper seals are missing. What do you all think?
And moochessgrassyass for the help so far!
01 Jul 2008 21:10 #223421 by Sandy
Replied by Sandy on topic Friggin' Oil!!!! *update-still broke!*
Don't mess around...pull the exhaust and PUT THE GASKETS BACK IN!
Even though it's a P.I.T.A....DO IT!
The leaking cylinders might not be that bad right NOW,but your bike WILL,eventually start to run worse with leaky exhaust,especially right at the head.
1977 KZ1000 A-1
02 Jul 2008 19:25 #223618 by steve3408
Replied by steve3408 on topic Friggin' Oil!!!!
So whats the spring and check ball inside the oil filter bolt do? and what the heck is that thing that is above the filter,..."filter plate"??...dont remember anything like that inside my '79 and '80 A4's,will the check ball oil filter bolt help out an older KZ? should the KZ's have that oil filter plate on top?? whats it do?
1980 KZ1000 A4(bought new),1979 KZ1000 MKII(bought new),1978 KZ1000 A (sold)1979 KZ1000 B LTD (sold)1976 KZ900 LTD (sold)1978 KZ750 twin (sold)
  • KZQ
  • Administrator
02 Jul 2008 20:03 #223631 by KZQ
Replied by KZQ on topic Friggin' Oil!!!!
The spring and check ball allow oil to bypass the filter when either the oil is too thick/cold to flow through the filter or the filter is too plugged to allow the oil to flow.
The filter plate is designed to shield the filter from the direct flow of oil from the engine so that trapped debris does not get dislodged. Some KZ's mount them from the top and some from the bottom, depending on the oil flow.
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
