cylinder block boring
- roystaylor
30 Jun 2008 18:05
If a single cylinder is found to be out of tolerance, can just that cylinder be rebored and fitted with a new piston / rings or must all be done?
if all must be done, is this for balance purposes?
- Becker
- The Doctor Will Rise Again
Re: cylinder block boring
30 Jun 2008 19:14
You could, if you absolutely had to, bore just the one cylinder but it is generally considered a bad practice. The reason is that displacement = horsepower. That one cylinder will make slightly more power, need a slightly bigger jet, and make general tuning more difficult. I don't know this from experience because I've never bored just one. If one is out of clearance I always bore them all.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
- APE Jay
30 Jun 2008 21:21
If you are talking stock pistons, it would not be a problem. They make .020" over and that wouldn't be noticeable.
Jay
Jay
