KZ1000 O-ring between cylinder liner and jug
- oldkaw79
30 Jun 2008 09:33 #223055
by oldkaw79
KZ1000 O-ring between cylinder liner and jug was created by oldkaw79
Does anyone know what the o-ring between the cylinder liner and aluminum jug do on a KZ1000? What would happen if one of the o-rings is missing?
- Mcdroid
- Gone Kwackers
- Thank you received: 317
30 Jun 2008 10:01 #223064
by Mcdroid
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Replied by Mcdroid on topic KZ1000 O-ring between cylinder liner and jug
Are you writing about the one that goes on the bottomside of each cylinder liner? If so, I suspect it has to do with the oil splash that might result from the connecting rods, piston bottoms, etc. I have always replaced them when I pull a set of jugs, but I am aware of others who haven't bothered and they didn't report any oil leaks at the base of the cylinders.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- bountyhunter
- Thank you received: 337
30 Jun 2008 12:09 #223092
by bountyhunter
Replied by bountyhunter on topic KZ1000 O-ring between cylinder liner and jug
I wondered about that O ring too. That surface between the cylinder and crankcase has the base gasket there, so you would think it would not leak oil if the large O ring was missing.
I thought that large O ring might assist in sealing the cylinder compression by not letting it push back on the base gasket. As the pistons move up and down, they do exert some pressure into the crankcase which is releived by the crankcase vent.
- APE Jay
- Banned
- Thank you received: 58
30 Jun 2008 14:52 #223117
by APE Jay
Replied by APE Jay on topic KZ1000 O-ring between cylinder liner and jug
They are missing on all blocks that have had oversize sleeves installed, with no apparent problem
Jay
Jay
- oldkaw79
02 Jul 2008 09:50 #223500
by oldkaw79
Replied by oldkaw79 on topic KZ1000 O-ring between cylinder liner and jug
I have rebulit a couple of KZ's and have replaced them also when using stock jugs. My friend asked me what them were for and I could not find a reason also. Thanks for the responses.
