How to Identify a kz650 engine?
- dfcm2003
29 Jun 2008 17:58 #222917
by dfcm2003
How to Identify a kz650 engine? was created by dfcm2003
Hi all,
Im new here, and I just purchased 2 kz650 engines. I am planning on using one of them in a Golf Cart, yet I have no idea which model of engines they are? I was wondering if anyone here could help me figure out what model they are?
I looked all over the engines and I found this on both.
0652l (im assuming its an l, it looks like a cursive l)
and Made in Japan
I have all the parts for the engines, the main blocks are together, but I have to place the carbs on etc..
I have a bunch of extra parts as well. I need to purchase a manual but I have no idea on which manual to get.
Also: one motor looks to have points, and the other an electrical point system?
Thanks for help and time.
Daryl
and Made in Japan
Daryl
- Scatdrat
- Constructing Scat Rat out of a 78 650D SR
29 Jun 2008 18:31 #222932
by Scatdrat
Scat D Rat
'78 KZ650 D1A SR
Replied by Scatdrat on topic How to Identify a kz650 engine?
OK, you should be able to find the VIN on top of the case, on the right side, above the clutch, facing up. Check out the VIN lookup function on
www.cyclepartsnation.com
to tell you what years they are and get the right manual.
The 0652 is for the 652cc engine size, as for the "L" that symbol on mine is in reference to the oil volume, not engine size.
Originally the engines were made with point ignition. Later after market parts like the Dyna S ignition system have replaced many OEM points.
Hope this helps.
Hope this helps.
Scat D Rat
'78 KZ650 D1A SR
- steell
29 Jun 2008 20:04 #222955
by steell
Replied by steell on topic How to Identify a kz650 engine?
77-80 had points, 81 and later had electronic ignition and no kickstart.
Should say something like KZ550BEXXXXXX on a flat pad right above and behind the kickstart lever.
XXXXXX will be numbers.
- The Gringo
- ¡Usted no necesita otra motocicleta!
- Thank you received: 11
29 Jun 2008 21:50 #222980
by The Gringo
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Replied by The Gringo on topic How to Identify a kz650 engine?
If it isn't sitting in Bad Kaw's garage it could be a 650.:laugh: :ohmy: Sorry that was mean but I couldn't help myself.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- dfcm2003
30 Jun 2008 04:37 #222992
by dfcm2003
Replied by dfcm2003 on topic How to Identify a kz650 engine?
Hey thanks guys,
one was a 79 C3
and the other was an 81 H1.
lol the motors where so dirty, that I didnt even see that flat spot. Thanks for the information.
Daryl
one was a 79 C3
Daryl
- JMKZHI
- Thank you received: 48
30 Jun 2008 05:42 - 04 Dec 2008 07:11 #223001
by JMKZHI
Replied by JMKZHI on topic .
del
Last edit: 04 Dec 2008 07:11 by JMKZHI.
- Spot
08 Jul 2008 09:49 - 08 Jul 2008 09:52 #224891
by Spot
Good judgment comes from experience, which usually comes from bad judgment. - Will Rogers
Replied by Spot on topic How to Identify a kz650 engine?
I can't find the vin locator on cyclepartsnation. What am I missing?
Last edit: 08 Jul 2008 09:52 by Spot.
- dfcm2003
08 Jul 2008 13:02 #224934
by dfcm2003
This will help you
models.kz650.info/index.htm
I could never find it on the cycle parts nation either.
