Finally found out why my kz 400 wasn't running on both cylenders
  • oldkaws4ever
  • oldkaws4ever's Avatar Topic Author
  • Have no regrets...... You only live once.
29 Jun 2008 15:04
#222889
Gawd i wish i had thought about this earlier . I have been trying to track down the reason my 1976 kz 400 wasn't running on both cylenders. I did everything i replaced the coil, points and condensor, new battery, and cleaned the carbs 6 times. The other day i figured it would be a good to check the valve clearence, since its got over 10,000 miles on her. The 1st cylender (left side), was with in spec. Now comes the 2nd cylender (right side), go to stick in the feeler gauge, and its to tight. I didnt have a feeler gauge thin enough to fit in. I thought to my self, hey this is probally why it isn't running on both cylenders. So i adjusted it till the clearence was within spec. Ill know for sure when i get to fire her up in acouple of weeks.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
Re: Finally found out why my kz 400 wasn't running on both cylenders
29 Jun 2008 20:29
#222962
Why do y ou have to wait 2 weeks before firing it up?:blink:
1977 KZ1000 A-1
  • oldkaws4ever
29 Jun 2008 20:44
#222965
because im in the process of rebuilding it. And am in the process of getting some gaskets for it.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
29 Jun 2008 20:54
#222970
Gotcha.
Let us know if that was the problem.B)
1977 KZ1000 A-1
  • oldkaws4ever
29 Jun 2008 21:56
#222983
will do
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
