Tool Help Needed
- Ilbikes
The two wire rods that slide under the pistons from each side are there to prevent the pistons from moving and keeps them all equal in height. Are these perfectly round, oval, or flat? From photos they look round.
Lastly, what is their thickness/height (diameter if round)?
I just tried using my Motion Pro ring compressor tools and clothes hanger wire, but the soft wire deformed while the cylinders were being fitted and I torn my new base gasket upon removal of of those same poorly designed and home-made "clothes hanger piston stoppers". I need to visit the welding supply store and buy me some tig wire near the same diameter. Your input will be much appreciated.
I've looked for weeks for the right tool, but the cheapest one has exceeded $250 plus shipping on EBay. I need it one time and while I like tools, this is more than I can justify.
Thanks again,
Gordon
- steell
- bountyhunter
- Thank you received: 337
I would like to ask a favor from one of you having the Kawasaki factory Z1/KZ900 piston ring compressor tool set.
Thanks again,
Gordon
If you mean props to go under the pistons while installing the cylinder: I made mine out of some small paint stir sticks I got from home depot. I cut them to the length I needed, stacked a few up and duct taped them into a block. Make as many as you need. Worked for me.
- bountyhunter
Save it to use as a pattern. Make a new one out of the gasket material at Pep Boys. 1/32", rubberized fiber material. That's what I used for the base gasket on my engine and it worked perfectly,.
- bountyhunter
Install the middle pistons into the cylinder first: the piston heights are not all the same when doing this (the middle ones are a little higher). Prop the middle pistons from underneath, get them started into the cylinder (rings in) by tapping the cylinder down gently.
Then, rotate the crankshaft JUST ENOUGH to raise the outer pistons until they are far enough up to get a prop under them. apply the ring compressors to the outer pistons and tap the cylinder down so all four are in.
An assistant is very helpful to wrangle the pistons as the cylinder is tapped down.
