Where to find top end gaskets for a 1976 kz400?
- Jhay77
- SPARKY47
- 1980 KZ500 B2
- Thank you received: 5
1980 KZ500 B2
- The Gringo
- ¡Usted no necesita otra motocicleta!
- Thank you received: 11
He has a huge hoard of NOS Kaw parts. That gasket should be pretty easy to find because Kaw had a problem with the early KZ400's leaking oil from the head gasket and came out with a kit to fix them. The problem was that they leaked oil usually not compression. They solved the problem in 78 when they redesigned the engine to have an external oil line to oil the topend.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
- bountyhunter
- Thank you received: 337
- Jhay77
- SPARKY47
- 1980 KZ500 B2
If you're prepared to pay postage from Holland then there's one here. [11004-1003 has been replaced by 11004-1259]
Plus a whole load of spares for many Kz400's.
Plus other models:woohoo:
www.cmsnl.com/kawasaki-1976-kz400-d3_mod...partslist/52501.html
All the Best.
1980 KZ500 B2
- bountyhunter
I recently acquired a 76 kz400 and am in the process of trying to solve the low compression issue it has in one cylinder. I have removed the head and intend to lap the valves and possibly replace the piston rings(since I'm there already). The problem I'm having is finding a set of gaskets for this particular year. They are all over ebay for 77-78 bikes, but I can't find anything on the web for a 76? Any ideas?
If a '77 KZ400 gasket set is the same as '76, here's a set:
www.oldbikebarn.com/Motorcycle_Parts/Com...na-Engine-Gasket-Set
If it was mine, I'd go to the OEM part lists and verify which gaskets are the same for both '76 and '77. If the major gaskets like the head gasket, valve cover, base gasket are the same it's worth getting the kit. You can usually find the O rings by size from O ring supply houses if they all are not identical.
- Jhay77
