think ive got a big proble
- matcodude69
27 Jun 2008 17:13 #222590
by matcodude69
think ive got a big proble was created by matcodude69
so i got this kz 550 for trade for an older bike i had he said it ran and it does but only on 3 cylinders i tried spraying gas in the carb of the 1 that didnt work., and it shot the gas right back at me frome my basic understanding of ingines it should be pulling are in right do you think it is posible i could have head damage like a busted or bent valve
- Thank you received: 2098
27 Jun 2008 20:04 #222605
by Patton
Replied by Patton on topic think ive got a big proble
matcodude69 wrote:
Welcome aboard, matcodude69! We're glad you're here!
Would check the valve clearances. Might discover one or more being too tight, especially intake valve on the non-running cylinder. An intake valve which fails to close can spit back through the carb. Maybe adjustments of valve clearances to specs could resolve the issue.
Good Luck!
Good Luck!
- matcodude69
27 Jun 2008 21:51 #222620
by matcodude69
Replied by matcodude69 on topic think ive got a big proble
thanks will check that
