Head Gasket?
  • gargoyle
  • gargoyle's Avatar Topic Author
Head Gasket?
26 Jun 2008 16:55
#222379
Hi I'm in the middle of putting my 78 KZ650SR engine back together. There is a head gasket on e-bay for $25.00 listed as NOS Part # = 11004-1005. When I look in the Kawasaki Parts Diagrams the PN is 11004-1107. Does any one know if the e-bay gasket will work?
Thanks
1978 KZ650sr
Woodstock, Ontario
Canada
  • JMKZHI
  • JMKZHI's Avatar
Re: .
26 Jun 2008 19:04 - 04 Dec 2008 06:58
#222410
del
Last edit: 04 Dec 2008 06:58 by JMKZHI.
  • gargoyle
Re: Head Gasket?
26 Jun 2008 19:26
#222421
Thanks JMK
I've found another reference to the 11004-1005 PN
Fits models:
Z750 1980 - 1983
Z650 1977 - 1983
ZX750 1983 - 1985
Part number:
Supercedes 11004-1107
How can the same head gasket be used for a 650 and 750?
When you bore the cylinders do you still use the same Head gasket?
1978 KZ650sr
Woodstock, Ontario
Canada
  • gargoyle
Re: Head Gasket?
26 Jun 2008 19:33
#222423
Just checked the Kawasaki parts diagram for a ZX750-A1 (GPz 750) (1983)and it lists 11004-1107 for the head gasket.
Looks Like 650's and 750 use the same head gaskets. Is this right? Can any one confirm this?
1978 KZ650sr
Woodstock, Ontario
Canada
  • gargoyle
Re: Head Gasket?
26 Jun 2008 19:56
#222432
Thanks for the tip JMK Clicked on the (yellow and black ?) and the following bikes use the same gasket
KZ650-B1 (1977)
KZ650-B2A (1978)
KZ650-B3 (1979)
KZ650-C1 (Custom) (1977)
KZ650-C2 (Custom) (1978)
KZ650-C3 (Custom) (1979)
KZ650-D1 (SR) (1978)
KZ650-D1A (SR) (1978)
KZ650-D2 (SR) (1979)
KZ650-E1 (LTD) (1980)
KZ650-F1 (1980)
KZ650-H1 (CSR) (1981)
KZ650-H2 (CSR) (1982)
KZ650-H3 (CSR) (1983)
KZ750-E1 (1980)
KZ750-E2 (1981)
KZ750-E3 (1982)
KZ750-F1 (LTD Shaft) (1983)
KZ750-H1 (LTD) (1980)
KZ750-H2 (LTD) (1981)
KZ750-H3 (LTD) (1982)
KZ750-H4 (LTD) (1983)
KZ750-L3 (1983)
KZ750-N1 (Spectre) (1982)
KZ750-N2 (Spectre) (1983)
KZ750-R1 (GPz) (1982)
ZX750-A2 (GPz 750) (1984)
ZX750-A3 (GPz 750) (1985)
Looks like the same gasket was used extensively for both 650 and 750 engines. Looks like the e bay one might work.
1978 KZ650sr
Woodstock, Ontario
Canada
  • JMKZHI
  • JMKZHI's Avatar
Re: .
26 Jun 2008 19:59 - 04 Dec 2008 07:01
#222434
del
Last edit: 04 Dec 2008 07:01 by JMKZHI.
  • bountyhunter
  • bountyhunter's Avatar
Re: Head Gasket?
26 Jun 2008 22:33
#222454
JMKZHI wrote:
This may not be much help, but I compared the 1005 & 1107 photos at bleablay - they sure look the same to me. And doing some cross-ref at Kaw.com, it appears that they are interchangeable.
Also, FYI, NOS does not necessarily mean it's a genuine Kawasaki part.
It might be a good idea to get verification. JMK.
EDIT: although, since they have the full part number, it's probably genuine Kawasaki.
Not necessarily.... the thieves at Fleabay know how to use the lookup engines too. I bought some NOS valves with the exact kawi part numbers in the ad and they were aftermarket. same with a set of pistons, exact Kawi part number, not a Kawi part... but the parts did fit OK and I am using them.
