77 kz650 cylinder gasket
- djcamp10
25 Jun 2008 20:53 #222217
by djcamp10
1977 Kz650 B1
77 kz650 cylinder gasket was created by djcamp10
Just lost the head gasket on my KZ650. question is as a mechanicaly inclined person how difficult of a task am i about to embark into and what are going to be the biggest obstacles. thanks for any help
1977 Kz650 B1
- brianpclarke
26 Jun 2008 00:26 #222245
by brianpclarke
-Brian
1977 KZ650C
1976 Kz900 LTD
Replied by brianpclarke on topic 77 kz650 cylinder gasket
to replace the head gasket... no problem at all...
Your gonna have to remove the tank, carbs, and coils... then just remove the valve cover. Now if you go further into the engine then you are going to have to reset the timing, take the exhaust off and head into the engine....which is kinda tedious. A Clymers manual is invaluable when doing these jobs.
-Brian
1977 KZ650C
1976 Kz900 LTD
- bountyhunter
- Thank you received: 337
26 Jun 2008 12:38 #222350
by bountyhunter
Replied by bountyhunter on topic 77 kz650 cylinder gasket
Spend the extra $ for the Kawi factory manual. It is definitely worth it. You will have to set the camshaft timing right or you will trash the valves, the FSM will say exactly how to do this..
It would probably be smart to have the valves lapped and replace the valve guide seals while the head is off.
- gargoyle
26 Jun 2008 13:10 #222357
by gargoyle
1978 KZ650sr
Woodstock, Ontario
Canada
Replied by gargoyle on topic 77 kz650 cylinder gasket
What brand Head Gasket are you looking at getting? I'm in the middle of a rebuild my self?
1978 KZ650sr
Woodstock, Ontario
Canada
- RonKZ650
- Thank you received: 240
26 Jun 2008 13:33 #222359
by RonKZ650
Replied by RonKZ650 on topic 77 kz650 cylinder gasket
If by "losing the head gasket", you're talking about an oil leak, that's not the head gasket leaking. 400 rubber orings in a KZ650.
