Air Filter Pods?
  • volsrock
  • volsrock's Avatar Topic Author
Air Filter Pods?
25 Jun 2008 20:38
#222208
1981 kz750/4
Should I get um or not?
Do I have to rejet?
  • bountyhunter
  • bountyhunter's Avatar
Re: Air Filter Pods?
25 Jun 2008 22:28
#222234
volsrock wrote:
1981 kz750/4
I wouldn't. The performance increase (if there is any at all) is not as much as the PITA they will be to get them running right.
volsrock wrote:
Do I have to rejet?
Very likely, that's the PITA part.
  • KOOL RYDER
  • KOOL RYDER's Avatar
  • KZ 650B2 / KZ 1000E
25 Jun 2008 23:25
#222241
YOur response is pricless.
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
  • Z1109R Fin
  • Z1109R Fin's Avatar
26 Jun 2008 03:35
#222257
Well, I wouldn´t say it like that. Depends what you´re after. Racing look and feel then definately! They look, sound and feel COOL! If it´s for daily commuting, cruising then I´d use air box and a good K&N filter in it to get better flow. I ride a pretty much modified ELR so just my 0,02€B)
Z1000R ´83...Slightly modified...
  • Locozuna
  • Locozuna's Avatar
26 Jun 2008 05:38
#222266
See that little box that says "search forum" up on the page. Put in "pods" hit enter and after about 1/2 hr of reading you will be an expert on the ups and downs of running pods. It's a difference of opinion that plays out at least 2 or 3 times a week.
Here are the cliff notes
Pods+
You need to squeeze every hp out of your steed
You do not mind noodeling around with your bike
You have the time and patience to noodle around
Ease of removing and installing carb rack
(The above + is nullified if you get new carb boots for your airbox)
Some say the looks of pods is a plus (subjective)
Pods-
Good pods are costly..cheap pods are useless
Lean out condition from side winds & passing semi's
Difficulty getting them dialed in
Yes, you will have to re-jet to realize the increase
Subject to rain and road splash
Cost of returning to airbox if pods don't turn out to be your thing (PS don't throw away your airbox)
Pods are really alien seed canisters that will suddenly open and suck your face off then destroy your brain forcing you to buy and ride a Harley....ok....ok..maybe not a Harley ...a Vespa!:blink:
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
  • wiredgeorge
  • wiredgeorge's Avatar
26 Jun 2008 06:26
#222273
Locozuna said, quote... Good pods are costly..cheap pods are useless... unquote
I think this statement is pretty much untrue. Emgo pods flow as well as K&N pods. Emgo pods are about a 1/4 the price. Their disadvantage is that they have paper elements and can't be cleaned where K&N are supposed to last a lifetime.
Also, a K&N drop in filter (in your airbox) is supposed to flow a lot better than a factory paper element. My testing hasn't shown that... the K&N may flow better in some applications but not in any I have tested. The K&N also introduces the very definite chance that the bike will run rich as MOST folks who own them over-oil them. More is always better, right?
I won't say much more about pods vs an airbox. This has been hashed out so much that it isn't worth getting into. At some point, I suppose it would be a good thing for someone to actually write an article on the subject and put it in the Filebase as this question and the questions about oil have had sufficient airing.
