Sprocket spacer "collar" stuck?
  • LeeLewis7
  • LeeLewis7's Avatar Topic Author
25 Jun 2008 04:24
#222017
Is the sprocket spacer on the output shaft a press fit, or is mine just frozen? The parts diagrams refers to part as a "collar", and it rides in the oil seal in the transmission cover.
Anyway, it's frozen in place and it needs to come off before I can replace the big bearing behind it. Any suggestions for removal?
Chattanooga, TN
1984 KZ1000 P3 (Blue Shift)
kzrider.com/index.php?option=com_kunena&...8353&catid=11#218353
  • LeeLewis7
Re: Sprocket spacer "collar" stuck?
25 Jun 2008 08:39
#222065
Chattanooga, TN
  • rpkaw
  • rpkaw's Avatar
25 Jun 2008 13:56
#222132
The collar is a slight press fit and i suggest getting another one in case this one is damaged during removal. I've removed this collar with a bearing spliter and puller and i've also used an air hammer gently to remove it. Using the air hammer with either a punch or chisel will remove it but it also damages the collar. Either way get a spare collar in case it gets nicked.
  • FastKaw1
  • FastKaw1's Avatar
25 Jun 2008 15:09
#222146
Try putting it in the freezer for 24hr.
Then use a brass drift. It's worked for me in the past.
I have also used hose clamps (Two) one over the other and used a bearing
puller. It must be the hillrod in me.
XENU
  • LeeLewis7
25 Jun 2008 19:08
#222185
I'm going to try the freezer trick. It's in now, and I'll pull it out tomorrow evening and try heating the collar with a torch. With any luck it will pop off with a minimum of effort. I'm not too worried about nicking it, as it needs to be replaced. The associated oil seal (which is also being replaced) had deteriorated and worn a groove into the collar.
Chattanooga, TN
  • LeeLewis7
26 Jun 2008 17:38
#222386
Done. The freezer/torch combo seemed to work, though it still required a little BFH-ing.
Thanks all for the help!
Chattanooga, TN
  • FastKaw1
  • FastKaw1's Avatar
27 Jun 2008 04:58
#222484
I love it when a plan comes together.
XENU
