pistons worth fixing?
  • bizzyrider
  • bizzyrider's Avatar Topic Author
  • 1996 kz 1000 police
20 Jun 2008 20:09
#221246
I bought a 96 kz 1000 a few months back and just discovered it needs to be bored along with piston replacement. The shop wants to charge 1000 + or -. Am I getting soaked? I just want to check before giving them the green light.
1996 kz 1000 police
  • bountyhunter
  • bountyhunter's Avatar
Re: pistons worth fixing?
20 Jun 2008 21:20 - 20 Jun 2008 21:23
#221266
Is it going to include having the head done?Wouldn't make sense not to lap the valves and replace the seals at the same time.
If that $1k price includes all new pistons and rings, labor to remove and rebuild, it's not really out of line. The machine shop that bored my cylinder charged $75 per hole just to do the boring (carry in)which would be $300 for a quad. You can figure new piston/ring sets are probably $75 each or more unless you get lucky on ebay. You need top end gasket set so it's at least another $150 or more. Figure +$700 for parts and machine shop cost just to get off the ground. Doing all the labor for maybe $300 is reasonable. I wouldn't do it for that.
Last edit: 20 Jun 2008 21:23 by bountyhunter.
  • steell
  • steell's Avatar
21 Jun 2008 05:41 - 21 Jun 2008 05:43
#221299
Check out APE's prices for comparison.
Bore and hone (you provide pistons) $189
Bore and hone with purchase of pistons $120
Wiseco 1075 piston kit $466.61
That's $586.61 plus shipping both ways for your block (around $25) for a complete cylinder block ready to bolt on.
Figure 5 hours or so for labor (at $70 per hour?) $350
That's $961.61 (plus tax?).
Add in the $80 or so for a gasket set.
Anyone can bore a cylinder (even me), it's the honing that separates the winners from the losers, and APE's honing procedures are proprietary, I've been bugging Jay for a couple of years trying to get him to tell me his secret honing process with no luck :D
I'm determined to do everything myself on my KZ750E project, but unfortunately I have to pay someone to do the TIG welding, and because I want the very best ring seal on the 810, I guess I'm going to bite the bullet and pay Jay to do the bore and hone on it. :(
Last edit: 21 Jun 2008 05:43 by steell.
  • wiredgeorge
  • wiredgeorge's Avatar
21 Jun 2008 06:19
#221308
Why do the cylinders need to be bored? Did you measure the piston to bore clearance? Is there damage to the liners?
