- Thank you received: 48
- JMKZHI
20 Jun 2008 08:22 - 04 Dec 2008 06:41 #221105
by JMKZHI
. was created by JMKZHI
del
Last edit: 04 Dec 2008 06:41 by JMKZHI.
- RonKZ650
- Thank you received: 240
20 Jun 2008 08:34 #221108
by RonKZ650
Replied by RonKZ650 on topic Exhaust system gaskets or gasket sealant?
Unless yours are missing or damaged, just reuse the existing seals. They never need replacement unless they get goobered up somehow.
- OKC_Kent
- Thank you received: 20
20 Jun 2008 08:36 - 20 Jun 2008 08:38 #221109
by OKC_Kent
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
Replied by OKC_Kent on topic Exhaust system gaskets or gasket sealant?
I bought one for my 750 from the dealer a year ago; if I recall it was about $12. I think Z1 sells a few different exhaust gaskets too, have you checked or called them?
If you add your bike to your signature I'll look up the part number in my cross reference software and maybe they are used on other machines, you might be able to score some on Ebay cheaper that way.
Oklahoma City, OK
Last edit: 20 Jun 2008 08:38 by OKC_Kent.
- JMKZHI
20 Jun 2008 08:49 - 04 Dec 2008 06:42 #221111
by JMKZHI
Replied by JMKZHI on topic .
del
Last edit: 04 Dec 2008 06:42 by JMKZHI.
- RonKZ650
20 Jun 2008 09:42 #221121
by RonKZ650
Sealing them will just result in them being ruined if you ever need to disassemble in the future. The gaskets are asbestos type stuff that normally provides a good seal without aid of sealer.
- JMKZHI
20 Jun 2008 10:58 - 04 Dec 2008 06:43 #221130
by JMKZHI
del
Last edit: 04 Dec 2008 06:43 by JMKZHI.
- bountyhunter
- Thank you received: 337
20 Jun 2008 16:42 #221211
by bountyhunter
Replied by bountyhunter on topic Exhaust system gaskets or gasket sealant?
Don't they make the hollow copper "donut" ring gaskets in your diameter? Those are only a few bucks and have always worked on mine. If you have one pipe that comes in crooked to the head, you can glue two rings together if need be.
- wiredgeorge
20 Jun 2008 16:46 #221212
by wiredgeorge
Replied by wiredgeorge on topic Exhaust system gaskets or gasket sealant?
He isn't talking about the cylinder head exhaust gaskets... They ain't the crush copper gaskets.
