pos
- cutmesomeslackjk
19 Jun 2008 15:00 #220958
by cutmesomeslackjk
1980 kz 1000
with a 1974 z1 900 on it
electronic ignition from 1980
pos was created by cutmesomeslackjk
so i have not slept since yesterday stayed up all night to get the valves lapped and everything put in the head got it all together and pit it on the bike got it in time bolted everything up went to the dealer and got oil/filter/plugs and a new clutch/perch. got home drained the oil pulled the pan cleaned it out bolted it back up put the oil in put the new plugs in and i have really good compression...so i try starting the bike with the starter...it barely cranks over and then stops completely ...even with a fully charged battery...ok so i try using the kick start everything is going fine i have fire...i get tired of kicking comeback kick it almost another 50 times...and i realize something....the kick start is not turning the crank and i have no fire.....so now i have no way to even try to start it...im not going to buy a new starter for it and i can not even get the kick start cover off to look at it
1980 kz 1000
- Bullitt03737
19 Jun 2008 16:00 #220971
by Bullitt03737
1980 CSR 1000. New dyna Coils, Vacumn Less Petcock, Various Handle bars depending on the day, (Drag and Clubman.)
Replied by Bullitt03737 on topic pos
If you get sick of it ill buy it.
Sounds like you need to put that battery on a trickle charger over night and give her another shot.
- BSKZ650
- Thank you received: 14
20 Jun 2008 05:43 #221070
by BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
Replied by BSKZ650 on topic pos
is the battery new or at least good, and as stated, charge it over night.
the kick starter I think will come out of the side and you can look to see what is going on there
- OKC_Kent
- Thank you received: 20
20 Jun 2008 08:21 #221104
by OKC_Kent
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
Replied by OKC_Kent on topic pos
Just a thought, are you pulling in the clutch when you kick it? At least on the 650, leave the clutch out and bike in N when kicking.
Oklahoma City, OK
- cutmesomeslackjk
20 Jun 2008 12:48 #221171
by cutmesomeslackjk
1980 kz 1000
Replied by cutmesomeslackjk on topic pos
the battery is good and fully charged the starter/silonoid is junk and i have the bike and nutural and lave the clutch out when ever i kick it
1980 kz 1000
- Locozuna
20 Jun 2008 16:30 #221208
by Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
Replied by Locozuna on topic pos
Was the kick working before? You say you put a new clutch perch on it are you sure you adjusted the cable correctly and the clutch is not disengaged? Sounds too odd that the kick is not turning the engine. Snick it into 1st and see if if you can roll it.
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
