Z1,A,B Cylinders barrel fins rubber plugs/dampners
- luc
19 Jun 2008 08:24
On the outside of the cylinders barrels, between the fins, there are 8 rubber plugs dampners to, my guess is, limit vibrations.
They are not listed on any parts book but the part # is 92074-030 and they are still available from Kawasaki.
My question is do you know exactly where do they go.
There must be 4 in front and 4 in the back.
The barrels have 8 fins, between which fins fo they go?
- patmann
Re: Z1,A,B Cylinders barrel fins rubber plugs/dampners
19 Jun 2008 08:55 - 19 Jun 2008 08:57
In a nutshell.. they keep your bike from singing from the vibrations.
I'm sure others will jump in with a better explanation.
I'd have to look at my bike , and I'm @ work now. So I can't answer you on placement.
1974 900 Z1 modified to look like a LTD , some engine mods. But I still have all the original parts.
1977 1000 project bike
1972 H1 project bike
If pro is opposite of con, then what is the opposite of progress?
Last edit: 19 Jun 2008 08:57 by patmann.
- bountyhunter
19 Jun 2008 12:21
That's a trip down memory lane. Those things fell out of mine many years ago and I forgot they were ever there.:laugh:
- luc
19 Jun 2008 13:03
patmann wrote:
thanks, i will appreciate that
- coppertales
20 Jun 2008 12:32
I had an early Z1 and it did not have any plugs.....chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
1982 1100 SPECTRE
1982 1100 SPECTRE
- Mcdroid
- Gone Kwackers
20 Jun 2008 14:15
luc:
There are, as you know, four on the outside front of the cylinder block, and four on the outside rear of the block. They insert at the base of the block (lowest fin) between cylinders 1&2 and cylinders 3&4...and they are, as mentioned, vibration dampners. Sometimes they work loose and can be fixed in placed with silicone...but they ain't, as mentioned, critical...I keep mine because Mother Kaw put them there for a reason:)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- Ilbikes
21 Jun 2008 06:32 - 21 Jun 2008 06:44
Mcdroid is right - these go at the base of the cylinder in the holes not ocupied by the cylinder studs. The holes don't go all of the way through the top. They fit large-diameter down (towards the crankcase).
I just bought 8 of these for my KZ900 - they are about $2 each as I remember. I took my cylinder head to my local NAPA shop for their heated aluminum cleaning. When I got the cylinders back, two of those dampers were loose. I wanted to replace them all.
I also mastered getting back the factory-like shine to the cylinders and head without clear coat or polishing away the natural casting marks and imperfections. I'll share those secrets later when I'm done with the entire assembly. These were about as bad as any seen - dull and oxidized plus stained really bad.
Regards,
Gordon
Regards,
Gordon
Last edit: 21 Jun 2008 06:44 by Ilbikes.
- Mcdroid
- Gone Kwackers
21 Jun 2008 09:16
Ilbikes wrote:
[quote
I also mastered getting back the factory-like shine to the cylinders and head without clear coat or polishing away the natural casting marks and imperfections. I'll share those secrets later when I'm done with the entire assembly. These were about as bad as any seen - dull and oxidized plus stained really bad.[/quote]
Hello Gordon...looking forward to your expose on aluminum cleaning... is that an S90 as your avatar?
[quote
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- Ilbikes
22 Jun 2008 10:59
Yep, my first real motorcycle owned. I was 11 and it was 3. I've gone back and found every model I had growing up- well almost. I'm missing a 1975 GT550 in red.
- MLMG
- See you in the wind.
22 Jan 2023 09:50
Hello everyone, I was researching and it only uses 4 rubber stoppers, not 8, the old catalogs have errors.
The plugs come between the casing and the first fin to prevent accumulation of dirt.
1977 Kawasaki KZ1000 A1
The following user(s) said Thank You: Fox
- zed1015
22 Jan 2023 10:4115 year old thread back from the dead..Hello everyone, I was researching and it only uses 4 rubber stoppers, not 8, the old catalogs have errors.
The following user(s) said Thank You: hardrockminer, MLMG
