what do the stock pistons for a 1974 z1 900 engine look like?
- cutmesomeslackjk
16 Jun 2008 20:19 #220431
by cutmesomeslackjk
1980 kz 1000
with a 1974 z1 900 on it
electronic ignition from 1980
what do the stock pistons for a 1974 z1 900 engine look like? was created by cutmesomeslackjk
i was told my bike had a kit in it but i dont know for sure
also could someone decode these vin #'s for me
kzt00g-500087
and my engine vin
z1e048438
kzt00g-500087
and my engine vin
z1e048438
1980 kz 1000
- mtkawboy
- Thank you received: 16
16 Jun 2008 21:01 #220439
by mtkawboy
Replied by mtkawboy on topic what do the stock pistons for a 1974 z1 900 engine look like?
Not much to decode on the motor, looks like a 75 Z1B 900cc engine, the 80 number I have no clue about but they were all 1000's. Id guess thats a frame number which tells you nothing but the serial number
- wiredgeorge
17 Jun 2008 07:11 #220481
by wiredgeorge
Replied by wiredgeorge on topic what do the stock pistons for a 1974 z1 900 engine look like?
The frame VIN tells me that you have an early Z1 Classic frame 1980 KZ1000G1. Look at
www.zedder.com
to confirm. The stock pistons are a shade under 70mm (69.7mm I think) and have ART stamped on them with an arrow pointing towards the front if memory serves. The OEM piston will have a slightly domed top that is smooth. If you have aftermarket pistons there is usually something stamped on the piston that will indicate the manufacturer AND the domes will not be smooth and only slightly domed. They will usually have more pronounced domes and a non-symmetrical shape. The piston pins will be retained by thin wire clips if they are stock and generally be retained by thicker wire clips or circlips or buttons if aftermarket is used. If there is a kit in a 903 block, it can be no more than 1015cc (70mm diameter) unless new sleeves are used (I think this is true but I am old and my memory bad).
- mtkawboy
17 Jun 2008 08:41 #220492
by mtkawboy
Id say thats probably right, my 900 motor is sleeved to 1105. It belonged to a friend who let the bike set up and go to crap in the Fla salt air so I got it for free & paid $600 to have it shipped from Fla to Mt. He originally paid Superbike Mike close to $4500 for it back in the late 70s. I cleaned it up and went thru the top end and put it in a 78 frame I had
- cutmesomeslackjk
17 Jun 2008 12:50 #220525
by cutmesomeslackjk
1980 kz 1000
Replied by cutmesomeslackjk on topic what do the stock pistons for a 1974 z1 900 engine look like?
i went and measured the pistons turns out my bike has the stock pistons in it
thanks for the website with the vin numbers that was a big help i thought my engine was a 74 z1 but it is a 1975 z1-b engine
1980 kz 1000
- APE Jay
- Banned
- Thank you received: 58
17 Jun 2008 17:11 #220572
by APE Jay
Replied by APE Jay on topic what do the stock pistons for a 1974 z1 900 engine look like?
cutmesomeslackjk wrote:
We can fix that. We can turn that:( into a :woohoo:
Jay
Jay
- PLUMMEN
- Thank you received: 104
17 Jun 2008 20:03 #220616
by PLUMMEN
Replied by PLUMMEN on topic what do the stock pistons for a 1974 z1 900 engine look like?
Jay
- cutmesomeslackjk
18 Jun 2008 00:22 #220644
by cutmesomeslackjk
1980 kz 1000
lol yeah i bet you could change that...but i dont have the $$$$ for you to do so...all the project money i have for this bike is about $200 and that would not even buy me a stock kit
1980 kz 1000
