Z1B oil pan gasker. reuse or not?
- luc
16 Jun 2008 09:45
i just pulled the pan to clean it. the gasket look to be in perfect shape and stayed and the case.
Can i reuse it without having to worry about leaks or do i need to scrap the old one and put a new one on?
Thanks
Thanks
- Mcdroid
- Gone Kwackers
Re: Z1B oil pan gasker. reuse or not?
16 Jun 2008 11:04
When I pull a motor cover that has been on for a long time, I replace the gasket. That old gasket will be oil-soaked and form a less perfect seal when reused.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- bountyhunter
16 Jun 2008 13:57
I wouldn't use it. You can make a cheap one using gasket material from Pep Boys. Use the pan as the outline and cut it with an X-acto knife.
