first bike ever, 77 kz650
- southside76
bike does not run, so i need some tips on what i need to do in order to get ready to crank it up.
i used to be a mechanic (transmissions, front/rear differentials, transfer cases) but ive never worked on a motorcycle.
bike seems to be complete (missing any kind of air filter), and so far off the top of my head these are the things i think i need to do before i bother buying a new battery and trying to crank it.
dumping the gas tank and maybe sloshing around a little fresh gas in it , clean it out a bit maybe? new plugs, fresh oil, and i dont know jack about carbs but im sure they need some work, should i leave them alone and see if it will crank the way they are or should i pop them off and try to clean them a little without taking them apart?
sorry for all the dumb questions, any help is greatly appreciated, thanks in advance.
Houston, Texas
1977 kz650
- JohNLA
s49.photobucket.com/albums/f255/JohNLA_photo/1983%20GPZ%20550/
83 GPZ 550 Stock with 3600 miles_83s.
83 GPZ 550 4-1,pods,Mikuni 36,000 + miles
- anarki650
- Thank you received: 5
Great bike you picked up (of course I'm rather partial to the 77...), once you get her running you'll find out she's damn near bulletproof.
I belong to another forum that's 650 specific, forums.kz650.info/ , a great resource for any 650 owner. Not that you won't find tons of knowledge over here though either. Welcome aboard!!!
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
- bountyhunter
- Thank you received: 337
Sort of depends on how long it's been sitting.
Flushing the fuel system would be mandatory. Oil and filter would be a good move.
- Becker
- The Doctor Will Rise Again
- Thank you received: 1
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
- southside76
Houston, Texas
1977 kz650
- BSKZ650
- Thank you received: 14
if the gas smelled really bad then I would at the least pull the bowls off the carbs and clean them.
A new battery and fresh oil,and plugs try to fire it up, best case is it will run worse it wont you havent lost anything.
if it does start you will be able to see what needs the most work and make a list of all things needed.
If it dosent then pulling the carbs and a through cleaning, followed by new points, if it still has them,check the valves and voltage to the coils. make sure you have fire to the plugs, also run a compression check, all this is good for a base line
77 ltd1000, current rider
76 kz900, just waiting
- Becker
Oh ya, definitely new spark plugs. If there is just a little rust in there then maybe just leave it alone for now and you can always tackle that job after you've got it running.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
- anarki650
09 Kawasaki ER6n
Omaha NE
- agawam
- Marshall
- violentvintagecycles
If you dont want to take the carbs apart right away, at the bottom of each carb is a drain screw. Crack each one open and see if any gas comes out of it. If NO gas comes out of ANY carb you might be lucky and the previous owner drained the carbs before letting it sit. If gas comes out of any but not all your going to have to take the carbs off. If gas comes out of ALL of them, you might be able to get it started. Keep an eye on how that gas looks too, if its brown, carbs are gonna have to come off for cleaning anyway. If each carb has some gas coming out, close the drains, open the petcock and start cranking.
By the way, you said no air filter at all? Does it have an airbox or has it been removed. Im thinking if you do get it to start its only going to run while its choked.
