kz1000p cams- 102hp style, 92 hp style, or different?
- jcleach
11 Jun 2008 20:54
anyone know if it would be worth while to go from csr1000 cams to 1000p cams?
- steell
Re: kz1000p cams- 102hp style, 92 hp style, or different?
12 Jun 2008 04:10
According to my research, it's the same cam.
LTD and CSR cams have the same lift and duration, Standard (KZ1000J) cams have more lift and duration, with 83-84 GPz1100 cams having even more lift and duration than the KZ1000J.
I don't remember the specs on the 81-82 GPz1100 cams, or where they fit into the mix.
- jcleach
16 Jun 2008 13:09
what I am wondering is which one shares the same as the police cams?
- steell
16 Jun 2008 18:32
jcleach wrote:
There is a former member that is an expert on the P models, and according to him they used a CSR motor with CSR cams. I don't have a P manual so I can't look up the specs to verify this.
