KZ550 - Anybody can identify this Pistons???
- flaviote
11 Jun 2008 20:28 #219500
by flaviote
KZ550 - Anybody can identify this Pistons??? was created by flaviote
Hi,
I'm from Uruguay and i recently brought a KZ500 to restore (i brought it cheap to restore all the bike, because i like to know what kind of bike i'm riding ).
The last month i brought some pieces in ebay, and today the parts come to my home; the parts was supposed to be KZ550 parts and i know that there is no problem to put 550 piston´s on KZ500.
But when i measured the piston's i noticed that are 60mm piston, and looks some strange.
Anybody knows what kind of pistons are?, because i need to buy the rings and i see that the compression rings are different (one is thinner).
Thanks in advance.
Flavio.
Thanks in advance.
Flavio.
- SPARKY47
- 1980 KZ500 B2
- Thank you received: 5
12 Jun 2008 02:45 #219557
by SPARKY47
1980 KZ500 B2
Replied by SPARKY47 on topic KZ550 - Anybody can identify this Pistons???
Hello Flavio,
Welcome to KZR !
I have a Z500,and a manual, and it tells me that the standard piston for the Z500 is 55x52.4mm.
For the KZ550A1 is 58x52.4mm.
The 1st oversize piston is +0.5mm. 2nd oversize is +1mm.
So sorry, I can't identify the pistons in your post,but they have a different skirt to mine,if thats any help.
Welcome to KZR !
1980 KZ500 B2
- flaviote
12 Jun 2008 20:46 #219710
by flaviote
Replied by flaviote on topic KZ550 - Anybody can identify this Pistons???
Thank you Sparky for the data
I think that the better is buy KZ550 Pistons and expand my cylinders, because 60mm to the original 55mm is too much.
Do you think that my cilynders can go to 58mm (550 size) without changing the original Cylinders?
- SPARKY47
- 1980 KZ500 B2
13 Jun 2008 14:23 #219849
by SPARKY47
1980 KZ500 B2
I have a Z500 which has been rebored to 2nd oversize and that makes 516cc. So No, you can't bore the sleeves that far but... I had access to a Z250 and tried the pistons on my rods, they fit. So if you can get 4 oversize of them with rings then the man will rebore to them.
Or, you could find a cylinder block from a KZ550 and use that.Use the 500 head.
[you would need to drill the main jet out from no 90 to at least 95].
Oh, and a bit of carb adjustment:blink:
Regards.Peter.
Regards.Peter.
1980 KZ500 B2
- flaviote
15 Jun 2008 08:30 - 15 Jun 2008 08:31 #220151
by flaviote
Thanks you Sparky.
I think that i´m needing to get a KZ550 Cylinder Block .
BR, Flavio.
BR, Flavio.
Last edit: 15 Jun 2008 08:31 by flaviote.
- flaviote
16 Jun 2008 15:59 #220385
by flaviote
I have another question, anybody know if GPZ550 pistons will run fine in the KZ550 Cylinders?
- Saki Jockey
17 Jun 2008 18:17 #220591
by Saki Jockey
Rob A.
550 A4
GTA,
Ontario, Canada
Replied by Saki Jockey on topic KZ550 - Anybody can identify this Pistons???
Bore and stroke are the same KZ550 to GPz (A, B, C & D1, H1, H2). Major differences in the engines are cams and carburetion.
Rob A.
550 A4
GTA,
Ontario, Canada
