blasting a head and cylinders
- gargoyle
11 Jun 2008 19:34 #219480
by gargoyle
1978 KZ650sr
Woodstock, Ontario
Canada
blasting a head and cylinders was created by gargoyle
Hi
I'm considering soda blasting my 650 head and cylinders to clean them and give them a nice finish. From what I've read in these forms the soda is very gentle on the aluminum and does a good job of cleaning. What areas of the head do i need to mask. I was thinking about installing the valve cover when I blast the head to keep the cam seats and valve tops clean. this would let me do both parts at once. What about the head gasket area? I've seen some pictures that look like the head gasket area was blasted too. I'd like to clean the cylinder tops. The soda shouldn't hurt the hard valve seats should it? I'm going to lap in the valves after blasting it. I think I should plug the oil ports to keep them clean. Sorry to ramble on and on :woohoo: any advice would be greatly appreciated.
Thanks Guys.
Thanks Guys.
1978 KZ650sr
Woodstock, Ontario
Canada
- APE Jay
- Banned
- Thank you received: 58
11 Jun 2008 20:20 #219493
by APE Jay
Replied by APE Jay on topic blasting a head and cylinders
You should have no problem.
Jay
Jay
- gargoyle
12 Jun 2008 11:05 #219625
by gargoyle
1978 KZ650sr
Woodstock, Ontario
Canada
Replied by gargoyle on topic blasting a head and cylinders
So the soda shouldn't harm the gasket area's? on the head or cylinders?
1978 KZ650sr
Woodstock, Ontario
Canada
- bubbap
- Ride it like you stole it!
13 Jun 2008 14:10 - 13 Jun 2008 14:12 #219847
by bubbap
1979 KZ650, Mac 4-2 exhaust. Restored after 25 years of sitting. Dyna elec coils, ignition. As old as I am, been in the family since new.
Replied by bubbap on topic blasting a head and cylinders
I actually glass beaded my head. I left my valve cover on to keep anything out of the valves, but removed the valves. Make sure you plug the valve guides. You will probably still get some particles in the cam area. Which is hard to clean out unless you are replacing the valve seals because you can't remove the spring seats without removing the seals. And to remove everything you will need an in head valve spring remover. If your not going to do any valve work and the valves seat properly it would be a good idea to leave them in, that way you don't get anything in your cams.
Last edit: 13 Jun 2008 14:12 by bubbap.
- mtkawboy
- Thank you received: 16
13 Jun 2008 21:05 #219916
by mtkawboy
Replied by mtkawboy on topic blasting a head and cylinders
You will never ever get all the glass beads cleaned out no matter how good of a job you think you did. The beads get into the metal itself. Looks pretty but very tough on the motors. Too late now but Id be looking for another motor. I know someone will disagree with this, whatever, learn the hard way. Ive seen too many of them ruined
