- Thank you received: 4
splitting case
- wagonmaster69
- 78 KZ1000A2 / 82 KZ1100 Spectre
10 Jun 2008 22:39 #219277
by wagonmaster69
splitting case was created by wagonmaster69
I am having trouble splitting the case of my 82 KZ1100 Spectre I have all the bolts off but the one for the oil filter is stuck can that be the resin that it will not split..
- another82kz
10 Jun 2008 22:53 #219278
by another82kz
\"Its all just a bunch of nuts and bolts.\"
1982 KZ1000LTD
1974 Superbeetle
1999 Grand Cherokee
Replied by another82kz on topic splitting case
I just had my case apart. There are 5 bolts that go through from the top side of the engine near where the starter mounts. There are also some main cap bolts underneath the smaller cover that have to be removed I believe there are 4. Make sure you remove the small lower cover first. Plus all of the external covers IE the clutch cover, alt cover, chain cover and inner cover where the shift "linkage" is hidden. Also it doesnt matter if the oil filter is on there but its gonna make a mess when you finally get it apart. I used a dead blow hammer to get the glue broken loose and then pryed it from the other half of the case.
1982 KZ1000LTD
1974 Superbeetle
1999 Grand Cherokee
- wagonmaster69
11 Jun 2008 12:15 #219376
by wagonmaster69
Replied by wagonmaster69 on topic splitting case
Thanks I will give it a try..
