Are these valve clearance tolerances too tight??
- XL777
10 Jun 2008 21:32 #219262
by XL777
2012 Triumph Bonneville SE black
1978 KZ1000 B2 LTD
Fresh top end rebuild
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
It is easier to say what I haven't replaced then what I have.
I must love this cruel mistress since she hates me
Are these valve clearance tolerances too tight?? was created by XL777
I just recently replaced all the valve shims on my 78 KZ1000,stock motor, 36,XXXkm. I re tested the clearances. they all are equal to 0.003th/inch/0.76mm. Is that too tight? according to the book that is dead even. However, I have been told it should be between 0.004-0.005th in
Original shims in the bike
Intake
1 2.35 mm
2 2.70
3 2.55
4 2.50
Exhaust original
1 2.65
2 2.70
3 2.60
4 2.60
What new shims I used
Intake
1 2.45
2 2.65
3 2.50
4 2.45
Exhaust
1 2.65
2 2.65
3 2.55
4 2.60
I did a compression test and my numbers read
1 120lbs up from 100
2 100 from 85
3 100
4 110 from 95
Intake
1 2.35 mm
2 2.70
3 2.55
4 2.50
Exhaust original
1 2.65
2 2.70
3 2.60
4 2.60
Intake
1 2.45
2 2.65
3 2.50
4 2.45
Exhaust
1 2.65
2 2.65
3 2.55
4 2.60
2 100 from 85
3 100
4 110 from 95
1978 KZ1000 B2 LTD
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
- chris41
10 Jun 2008 21:52 #219268
by chris41
Replied by chris41 on topic Are these valve clearance tolerances too tight??
I don't let em go under 4 thou 3 seems a bit close make sure you turn the motor over a few times and check again, never go on the first measurement especially if you've had the cams out.
Compression still seems a bit low even for a cold engine.
Chris
Chris
- PFC FNG
- I've got the sickness!!!
10 Jun 2008 22:16 #219274
by PFC FNG
I know it would not be any fun if it was easy, but does it have to be this much fun?
84 ZX750 GPZ (Waiting for paint)
Eastpoint, Mi
Replied by PFC FNG on topic Are these valve clearance tolerances too tight??
If the book says it's good, it probably is. If you are having a hard time swallowing the compression figures, try a wet compression test to try and determine if there is an issue with the rings or something similar.
Eastpoint, Mi
- donthekawguy
- Thank you received: 8
11 Jun 2008 00:00 #219287
by donthekawguy
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
Replied by donthekawguy on topic Are these valve clearance tolerances too tight??
.003 seems a little tight. I just did mine and went with .004 to .006. .006 as the max. Get them as close to .004 as possible. I think it's better too loose (.005-.006) than too tight.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- bountyhunter
- Thank you received: 337
11 Jun 2008 12:42 - 11 Jun 2008 12:45 #219381
by bountyhunter
Replied by bountyhunter on topic Are these valve clearance tolerances too tight??
The spec on my 750 twin is .002" - .004". I keep them in the .003" - .005" range. A shade to wide won't hurt much, a shade too narrow can destroy your head.
Those compression numbers are BAD news. Squirt oil in the cylinders and recheck. If they pop up a good bit, it means the rings are hosed. If they don't come up much, then the valves are toast.
Last edit: 11 Jun 2008 12:45 by bountyhunter.
- XL777
11 Jun 2008 18:19 #219454
by XL777
1978 KZ1000 B2 LTD
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
Replied by XL777 on topic Are these valve clearance tolerances too tight??
Sounds like group opinion is to allow more gap. I will drop down to the next shim size and see
1978 KZ1000 B2 LTD
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
