Offset Counter Sprockets: Nose or No Nose
  • Old Man Rock
  • Old Man Rock's Avatar Topic Author
10 Jun 2008 09:24
#219130
Hey all,
In my research for an offset counter sprocket (1976 KZ900-A4) with a ZX6RR rear swing arm, rim & Sprocket
that is a 520 width. Thanks to Steell, I have found a cross for a 530 rear sprocket. All was good, so I thought!
In contacting some of the sprocket manufacturers they only offer the 630 without noses. The 530 CC sprockets are available with noses.
Question, WTF is the nose for?
Assumption is for bearing support but not sure, is this correct?
I just don't see how this (nose version) would work...
any ideas out there?
Thanks,
Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • racer54
  • racer54's Avatar
Re: Offset Counter Sprockets: Nose or No Nose
10 Jun 2008 10:05
#219140
Yep...the nose is for it to fit in the bearing support.If you don't run a bearing support (some don't on the street)then you don't need the sprocket with a nose. 5/8" over offset or more should run a bearing support just for the added strength although I have seen a dragbike running in the 8's without one, but most racers will tell you that is taking big chances on your trans.
  • Robinjo
  • Robinjo's Avatar
10 Jun 2008 11:29
#219149
And if you want to use the bearing support you have to get rid of the nicely shaped stock sprocket cover???
Moto Martin Z900 1981/73 engine
  • zombiescustoms
  • zombiescustoms's Avatar
11 Jun 2008 04:11
#219297
When I used to dragrace a 1979 Z1R about 10 years ago, I had a 5/8 offset sprocket and a outer support plate, but no bearing , I had a countershaft sprocket come off going through the traps at the big end of the track, going 140+, in my opinion you should never NOT run a bearing support, I could have been serioulsy hurt or killed when the chain rapped up around the rear wheel and sprocket!!
1979 KZ1000 drag/street fighter
1015cc stock internals for now, 39 flattys, GSXR frontend, ZX9 rear wheel with 6 over chromoly arm, just a budget beater!
  • FastKaw1
  • FastKaw1's Avatar
11 Jun 2008 05:07
#219299
Yep
With a good rear tire and lots of traction a KZ frame wont take it.
You also need to change the upper rear motor mount. (The long bolt+spasers)
I RUINED a motor and trans that way. (pulled the countershaft out of the case)
XENU
  • Old Man Rock
11 Jun 2008 05:28 - 11 Jun 2008 05:29
#219301
After reading postings on the matter I decided to stay with an 1/2" offset to clear the frame. I just don't like the idea of weakening(heat/clamp/hammer) the frame due to the 5/8" length.
Mill the rear wheel hub down and go with a 170mm vs.180mm tire if required.
As for the bearing support, I don;t think I'll be needing it for I just don't see my old ass going 140mph :woohoo: for may cause me to crap my pants...lol!
Thanks for the reply guys,
Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 11 Jun 2008 05:29 by Old Man Rock.
  • Bad Kaw
  • Bad Kaw's Avatar
  • Flying Squirell
11 Jun 2008 20:43
#219506
FastKaw1 wrote:
Yep
XENU
What do you "do" at the rear motor mount?
-KR
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
  • FastKaw1
  • FastKaw1's Avatar
12 Jun 2008 05:07
#219571
quote]
-KR[/quote]
Build/buy one.
It's a solid aprx. 5/8 bar stock with tabs welded to the bar for the mount.
Bar is then drilled on each end. gut to fit in-between the frame were the old
OEM mount went and then bolted from the out side in.
Hope I explained that well enough?
That type of mount is a must for large tire
traction. It keeps the motor from torquing in the frame.
I made several about 15yr. ago, worked quite well. I may still have a couple
in a box some were. If you need one. I used to have mounts, oil gates, an windage trays
that I would sell at the track. Help out the cost of entry fees. I know I have some.
Finding them, now thats different story.
XENU
  • Bad Kaw
  • Bad Kaw's Avatar
  • Flying Squirell
30 Jun 2008 21:34
#223221
Yes, that clears it up. Email sent.
-KR
78 Kawasaki Z1R
70 Kawasaki KV75
