Will the compression go up with correct valve clearance?
- OKC_Kent
06 Feb 2006 08:03
In my other post about
my valve adjustment
I found my intake clearances were none to very small. I could rotate the buckets on the 0 clearance valves.
Now that they are set correctly, could I expect the compression to go up a bit? My readings 2,000 miles ago, cold, before I got the bike running after a few years sitting, varied from 125 to 145. I can't test the compression now, my tester is "borrowed".
Kent
Kent
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
- wireman
Re: Will the compression go up with correct valve clearance?
06 Feb 2006 08:06
if any of the valves were hanging open bfore there should be an improvement,is it running better now?
- OKC_Kent
06 Feb 2006 08:36
It runs great, but any difference in performance is too small for me to notice.
Oklahoma City, OK
- crewzzn88
10 Feb 2006 21:08
just wondering where you bought your "sims" at. I may need to adjust my cam's too.
- loudhvx
10 Feb 2006 22:31
With small clearances, you will most often notice problems when the bike is real hot. Ride on an expressway for 15 or 20 minutes hard then come to a stop. Usually the engine will die. If you keep it revved it should stay running. This is because the valves no longer seal because the stems have become longer. Obviously this is very bad for the valves.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
