wiseco gaskets / base gasket
  • eel
  • eel's Avatar Topic Author
07 Jun 2008 06:07 - 08 Jun 2008 17:14
#218510
i had put my motor together and im getting an annoying leak (wetness) from the bottom gasket or orings. i want to change out the gasket and orings (going with kawasaki gaskets this time :) but my question is.. can I re-use my fiber/steel core wiseco gasket or should i order a new one?
1984 GPz750
2007 ZX6R
53-Racing.com - My Website
My GPz
Last edit: 08 Jun 2008 17:14 by eel.
  • SLEEPER650
  • SLEEPER650's Avatar
Re: wiseco gaskets
07 Jun 2008 09:43
#218539
replace it you already crushed the fire ring! never reuse a head gasket
78 650sr my baby
78 650sr waiting for rebuild
82 kz1100
  • APE Jay
  • APE Jay's Avatar
Re: wiseco gaskets
08 Jun 2008 16:54
#218787
The Kaws with stock studs have issues with base gasket leakage. The Wiseco / Cometic should be a better item than oem.
Jay
  • eel
Re: wiseco gaskets
08 Jun 2008 17:06
#218789
Well the motor is obviously not stock bore, so im going with the wiseco head gasket.. and i just noticed cometic has a head gasket that fits this wiseco kit.. interesting..
but alas, the problem is on the base gasket, not the top.
Why are the studs an issue?
1984 GPz750
2007 ZX6R
My GPz
  • bountyhunter
  • bountyhunter's Avatar
Re: wiseco gaskets
08 Jun 2008 18:18 - 08 Jun 2008 18:22
#218812
The base gasket on the rebuild kit I used on my 750 also failed. I made the next one out of the vulcanized fiber gasket material (rubberized paper) they sell at Kragen's which is .032" thick. I think the type number stamped on the paper is 8904 or similar. I cut it out with an X-acto knife and it has held up great.
If you have a base gasket leak, use Yamaha 3-bond or similar on the base gasket. That type of adhesive was used at the factory on the base gasket of my 750 and it ran 30 years without leaking. IMHO, base gaskets need to be affixed with it because you might have to pull the head at some point and you wouldn't want the cylinder rocking the base gasket seal loose while you are yanking on the head.
Last edit: 08 Jun 2008 18:22 by bountyhunter.
  • eel
Re: wiseco gaskets
08 Jun 2008 18:28
#218816
i was going to 1194 the next base gasket even though the shop manual says not to. there are already areas of the head gasket the manual says to apply sealant to (i used 1194).
i think, even without the adhesive, there is some kind of bonding that happens because i have never had a cylinder come off clean from the crankcases, th base gaskets are always ripped and broken even if they have only been on a few weeks.
1984 GPz750
2007 ZX6R
My GPz
  • APE Jay
  • APE Jay's Avatar
Re: wiseco gaskets
08 Jun 2008 21:31
#218870
All Wiseco gaskets are Cometic. When the engine is running, it is trying to lift the head and block off of the cases, With modified motors, this is even more pronounced. The stock studs will stretch while the engine is running and this lets the cylinder block pound out the base gasket.
The California Highway Patrol had a problem with this, requiring the mechanics to pull the entire top end to replace base gaskets. We took the problem to Cometic, and they made us base gaskets for the CHP that would live.
I won't even tell you how many big bore Kawasakis CHP had on the road:woohoo:
Jay
  • eel
Re: wiseco gaskets
09 Jun 2008 05:10
#218896
Hey thanks Jay. Will a set of aftermarket studs help solve the issue ?
The bike is a road racer (see my web page) so it spends most of its days around 8000prm, stretching the studs :)
1984 GPz750
2007 ZX6R
My GPz
  • APE Jay
  • APE Jay's Avatar
Re: wiseco gaskets
09 Jun 2008 09:19
#218942
Yes, by all means, that bike needs aftermarket studs.
kzzone.com/studs.html
Jay
  • eel
Re: wiseco gaskets
09 Jun 2008 09:51
#218945
i will order some studs... should i get anything else while im there that could help in other areas :) ? some nuts aswell i suppose.
is it easy to change out the studs? Special tool?
1984 GPz750
2007 ZX6R
My GPz
