Small exhaust holes
- BIGD
Small exhaust holes
06 Jun 2008 16:40
I was hoping someone could give me a fix on 2 small holes, each on either sides of my mufflers. They are not large and would like not to replace the exhaust until the fall. If someone could direct me to new exhaust system for my bike, if not a good aftermarket quiet product I will thank you in advance.BIGD
1981 KZ1000M1 Toronto,Ontario,Canada
Had 1981 KZ1000 M1 From 1981-1995 Canadian Model
Have 1981 KZ1000 M1 US Model
- KZQ
- Administrator
Re: Small exhaust holes
06 Jun 2008 16:55 - 08 Jun 2008 11:26
Are you sure you aren't referring to the moisture vents that all stock exhaust systems have? Are the holes round as if drilled into the bottom of the pipes just before the mufflers? If so they're supposed to be there.
KZCSI
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
Last edit: 08 Jun 2008 11:26 by KZQ.
- BIGD
07 Jun 2008 10:12
Yes that is quite possible, I will double check, but there is exhaust leeking from the cross piece that joins each side of the system, maybe there is some way to seal that area temporarily.Thanks BIGD
1981 KZ1000M1 Toronto Ontario Canada
- KOOL RYDER
- KZ 650B2 / KZ 1000E
09 Jun 2008 15:01
I used aluminum foil tape for a temporary fix.
It doens last long, but it doesnt cost 10 bucks either.
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
1978 KZ650B
1979 KZ1000ST
- Becker
- The Doctor Will Rise Again
09 Jun 2008 18:43
There is an article in the data base about fixing exhaust using stainless steel pieces and JB weld. maybe you could get some ideas from that.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
- silverhammer
09 Jun 2008 23:53
I've plugged some small one's with a sheet metal screw with washer
Silvrhammer
Silvrhammer
